Tried search, couldn't find...fog bulb replacement?
check your owners manual for detailed instructions.
but here is the abridged version.
The underside of the bumper, directly below your foglight housings, is a small square hole. Put an extended 10mm socket up in there and remove the bolt holding the housing in. After that take a flathead screwdriver with tissue over the head, and place it between the foglight housing and the bumper (on the side closer to the middle of the front bumper) and pry the housing out *gently*. After that take a screwdriver and loosen the screws on the back of the housing and rotate the bulb out, then replace the bulb. Then put everything back together.
The only frustrating part is getting the bolt back up through the bottom of the bumper and into the housing, don't get too frustrated, it will align eventually.
Good luck.
Also, the bulbs are 9006 HB4
Good luck.
Frustrating is an understatement. It took me about 20 minutes to get the drivers side to align. I ended up jacking the car up to get a better view (which actually made the whole process much, much easier when I did the passenger side). The passenger side lined up perfect though and the entire replacement time for that side was about 6 minutes vs 36 for the driver's side (first time doing it).
Good luck.
Good luck.
Sippy Cup (x2)
Here's info from the Sylvania Website...
The 9006ST should be fine...the list as a replacement bulb below.
2002 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
1156A
1156AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Tail light
7443
Stop light
7443
High mount stop light
7440
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
168
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
2002 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1156A
Tail light
7443
Stop light
7443
7440
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
168
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
2Poor 2Furious
Plenty of people have HID kits on their fogs. Since you have a 9006 kit, its pretty much plug and play. You just gotta find places to mount the ballasts.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
wusty23jd
09-24-2015 11:41 AM
yahelou
09-06-2015 09:12 PM
