Tray over the radio
A friend of mine just bought a 99TL . For some reason the tray keeps on popping out by itself when shes driving, has anyone had that problem before? Any input would help.
Yep - mine too. Way I see it, there are three options.
1. Super glue into place. Loses the functionality, but stops popping out. Remember to remove all CD's before you do it.
2. Each time it pops out, throw it in the back seat. My wife puts it back in each time she sees that I have done this, thus leading to my increased tendency to look towards solution #1 above.
3. Leave it alone and let it be. Somtimes I will take it out and leave it out for a day or two and then re-insert. For some reason, when I do this, it tends to stay "in" for at least 2-3 days before popping out. Also tends to pop out more in hot weather.
Hope this helps.
Hope this helps.
Believe it or not, there's a SB out for this. I had mine fixed gratis by the dealer. It involves replacing the latching mechanism in the bottom of the slot. Wish I could remember the bulletin number, but you can probably search for it.
I had mine replaced under warranty but it still popped out occasionally . My fix was to heat up(with a lighter) the tab on the backside of the holder itsef and apply a little pressure to bend it upwards and hold it till it cools and presto 8 months later with comptech springs, 8teens and NYC roads and it hasnt popped out once on its own .
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
