Transponder key
Transponder key
I just won a Transponder key on ebay and It says it was for a 00 acura integra. My question is are all transponder keys universal? Here is the link to it http://cgi.ebay.com/ebaymotors/ws/eB...ME:B:EOAB:US:6
I appericate your help!
I just bought a new one for my '00 TL, I'm not sure about the Integra, but the instructions given to me were as follows:
Acura keyless remote:
TO PROGRAM YOUR REMOTE CONTROL KEY FOB FOLLOW THIS PROCEDURE:
"Turn ignition to ON (without starting car) and within 5 seconds hit a button on the remote. Turn back to off. Repeat 3 times. After third time you will hear the doors click. Hit remote once more to verify."
Notes: 1) Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all the transmitters once you’re in programming mode. The system accepts up to three transmitters.
2) To keep the system from exiting the programming mode, complete each step within 5 seconds of the previous step, and program the transmitters within 10 seconds of each other.
Steps:
1) Turn the ignition switch ON (ll)
2) Press the “LOCK” or “UNLOCK” button on one of the transmitters. (A non-programmed transmitter can be used for this step.)
3) Turn the ignition switch OFF (0).
4) Repeat steps 1, 2 and 3 two more times with the transmitter used in step 2.
5) Turn the ignition switch ON (ll).
6) Press the “LOCK” or “UNLOCK” button on the same transmitter. Check that the power door locks cycle to confirm that you are in the programming mode.
7) Press the “LOCK” or “UNLOCK” button on each transmitter. (You can program up to four transmitter per vehicle.) Check that the power door locks cycle after you push each transmitter button, confirming that the system has accepted the transmitter’s code.
Steps:
Steps:
Steps:
soupi
14
Nov 15, 2015 11:15 AM
