Which transmission swap would you go with?
So my transmission died a violent death and needs to be replaced. I got an estimate on the following from a shop in Mountain View, CA:
Rebuilt tl transmission/w 1 year warranty: ~$2500
Used AV6 unrebuilt, no warranty: ~$3000
Rebuilt AV6 transmission/w no warranty: ~$3500
My car has 113k miles on it, so I think it's got a lot of life left in it.
I'm willing to spring the extra money for the AV6 swap, but am curious whether any of you with the Accord tranny have had any problems after putting in a unit that hasn't been rebuilt.
Between the rebuilt tl trans and a non-rebuilt AV6 trans, which do you guys think would be the better choice?
Mr.Helpful Diagram
I would say low mileage AV6 and a 3x3 of DW1 atf. Now $3000 for the trans, you need to keep looking theres other members getting them in the range of $1000.
I would go always with the UN-rebuilt AV6.. Why? Cuz you don't know the quality of the rebuild or what in fact they are charging with the rebuild.. Some shops just change the clutch packs and call it a day while some others rebuilt it to factory specs.
Whatever you do:
DONT GET ANOTHER TL TRANS!!!! It doesn't matter its rebuilt.
And what the hell with those prices? I got my AV6 for 900 bucks! another guy just got it for 700...
3000? Better get another complete TL-S or better yet.. Get a CL-S 6 Speedo and swap for the MANUAL and be one of the happiest man alive.
Whatever you do:
Installed prices....?
Are all of these prices including installation ?
Get a second opinion or two on the Accord V6's tranny swap as it seems too high....probably because the shop doesn't want to do it.
If ya should happen to decide that ya like their low ball rebuild offer, ya really need a much better warranty than one year, IMO.
In the long run, a low mileage AV6 will serve ya better....so look for another shop.
Thanks 3.2 TLc, I'll take that advice. I called around and found an AV6 with 67k for $1200 delivered from a local salvage yard. I'm waiting to hear back from the tranny shop as to whether they will do the swap for me or not. Said they'll get back to me tomorrow.
I'll keep you guys posted on how this swap goes. I think I'd rather have the AV6...
And yea, those prices all fluids and labor. Alternatively, if one of the forum members wants to help me do the swap I'd pay well for labor. ;-)
hey Kaiser, i got 2002 tl-s, since you live close by, pls let me know how you swap worked out. My tranny is working ok, but I dont expect to last a long time as I am not changing atf at all.
That's a very good point fsttyms1, I'll use the "replace" language from now on. I'll also consider the solenoids since I don't know what kind of condition mine are in. Those are expensive!
Guyenacurazine, I'll update this thread as things get done. I'm leaving for vacation on the 16th, so hopefully I'll be able to get this all done before then. If not, it'll have to wait till the new year.
Just my luck, car has to break down during the coldest part of the year. At least it don't snow in norcal right?
Dont call it a swap. Most shops run away from it or will charge you more since you are calling it a swap. Other than changing out a few sensors/range switch its a direct bolt on and nothing custom has to be done. Just ask shops how much to install a (new/used) transmission. Just take off the range switch and have them swap over your solenoids (or preferably get new ones and install them before they install the trans)
Eurotrash
Chris, just curious, why would you swap the older, probably more worn solenoids? I left all the solenoids and sensors in the low mileage accord trans. when I changed my daughter's. I did replace the 2 pressure switches later with new ones. (00 Acura application, not 07 Honda application) I did this because I'm getting a phantom pressure switch code; it doesn't even turn on the cel. The trans has no symptoms, and shifts fine. The switches didn't help.
guyenacurazine (12-11-2013)
i definitely feel hesitation during acceleration when in 3rd gear. it is mild for now. couple of shaking feeling lasts about a second or half. That is after I towed 2200lb about 1000miles for vacation trip
Wonder how kaiser.socei's tranny replacement is going. I am expecting my tranny will go belly up soon. Either will replace tranny with accord or just get a new car Would prefer cheaper option
Whatever you do:
Whatever you do:
Visiting back this thread, I went to another tranny shop recommended by the shop and they said they will only replace with the same tranny from manufacturer when I asked whether they can install honda transmission. Also they said they will rebuild. Looks like I hit a wall this time too.
Was looking for a shop who can install HONDA tranny. I remember in another thread folds who installed the honda tranny is doing well. I even remember I researched around and posted the 5figit tranny code in that thread.
IF possible i d really like someone or shop who can install CL6 manual tranny in many area. That would be awesome
Sigh, Thanks,
Sigh, Thanks,
Sigh, Thanks,
3.2TLc (06-21-2014)
Honda "AV6" or Acura CL "S" 6speed
Visiting back this thread, I went to another tranny shop and they said they will only replace with the same tranny from manufacturer when I asked whether they can install honda transmission. Also they said they will rebuild. Was looking for a shop who can install HONDA tranny.
IF possible i d really like someone or shop who can install CL6 manual tranny in many area. That would be awesome .....Sigh, Thanks,
Hey Guyenacurazine, if ya have a good solid 2nd Gen TL and it's in need of a tranny, then in reality..... the best cost effective remedy for the long haul would be the better designed "AV6" donor which is essentially a direct bolt-in replacement for our old original ailing and frail 5 speed AT.
While it's still possible to locate a CL-S 6 speed stick, there will be more labor expenses to have someone to install it for ya. But, if ya love your car and wanna have some true fun for years to come, just do it !!!
Check for a donor tranny to get an idea on availabilty and costs involved. For installing, research this site's "Regions" sub-forum. Ya may be able to get hooked up with someone closer to your area who can assist ya with finding an installer. Also, run the proposition by some of your local tranny or speed shops....as they may know of somebody willing to undertake your stick conversion project.
Actually there shouldnt be any more labor cost in just the installation of the trans. Everything is a direct bolt up and nothing special or custom needs to be done. Now having the rest of the wiring associated with the swap done will add more labor cost.
From the Same Manufacturer? Well that's HONDA! You can literally found Honda logos everywhere in the car..
Windows > Engine parts > Ashtray..
If they ask you even the Acura transmission is from Honda just tell them everything is from Honda..
Acura is just a Brand Name and TL is just an Accord on Steroids.
A lot of trans shops are scared of swaps since they have to give some sort of warranty on their jobs. If you install an Acura transmission (Ironic) to an Acura? Well they think it has to work spot on with no issues..
But a Swap? A swap can go wrong in many ways so they will have to deal with the aftermath.
Just buy the AV6 and don't tell its from a Honda just tell them its a newer version that was installed later in your TL gen life (Like the revision in trans installed in 2005 recalls) and you must install your Solenoids and ATF Warmer for it to work properly in your car since "Acura" didn't use the same ECU for those years.. If you have a 2001 tell them it comes from a 2003 with a revised 2005 transmission and done! No more issues.
Never use keywords like "SWAP", "ACCORD", "HONDA" in a Trans Shop..
Mr.Helpful Diagram
What about the power steering hose loop for the TL-p guys?
They will cry when they notice power steering sensor wont go on the new trans.
But by the time they notice it might be inside the car already.
I guess you can have the print out ready of the hose loop for them when they call you about it.
https://acurazine.com/forums/search....rchid=15346514
Check your auto recycler's who dismantle salvaged cars within your local area.
There's got to be a yard somewhere within driving distance near ya. They can help ya locate the "AV6" donor tranny and perhaps even install it for ya. They have connections with shops and mechanics who may be willing to do the work for ya. gotta be persistent.
i have dyi plan here posted on faq 06 07 but just double post here in case if you have any opinion:
I am actually considering the possibility that I do the swap myself into my tranny issue equation. I looked around places/individuals but no success. Shops wont do a swap but some ppl suggested dont tell at all it is a swap. That is possiblity but could it be risky?
For now I am just weighing the possibility and considering pros and cons of doing myself but not quite decided yet:
pros+
- Have a experiencing replacing clutch when I owned honda civic crx. But compared to it, it is much simpler design, manual tranny. That was long time ago. My financial situation is much better than I was in college during time I was working on my honda, so money is not a big issue.
- Thinking to rent a car storage and do it there since I live in condo. I have additional motorcycle so I can carry some tools/parts from stores while I am fixing
Now cons-
- it is a back breaking work, dealing with stuck bolts, or some unforeseen obstacles, felt the frustration before.
- Dont know how much complication will be during swap since I am first timer on this model
- I wont be able to do a grocery for some time
And some add'l question,
- I will definitely use this thread as a guide but most likely I will need either Helms or Haynes manual to do actual swap to through the steps. I do remember I used either oh these manual when I worked on my civic in the past, but dont remember which one. I do also remember one of them was suggested to be much more better, accurate and higher in quality than other by other members in the respective user forum, I dont remember which one.
- Prior to work, probably need to setup, rent storage place and major heavy tools required, most comes into mind is to rent engine lifter ready. What else???
pros+
Now cons-
DIY tranny swap.....pros vs: cons
pros+
- That was long time ago. My financial situation is much better than I was in college during time I was working on my honda, so money is not a big issue.
- I have additional motorcycle so I can carry some tools/parts from stores while I am fixing
Now cons-
- Thinking to rent a car storage and do it there since I live in a condo.
- It's back breaking work, dealing with stuck bolts, some unforeseen obstacles, felt frustration before.
pros+
Now cons-
Download a copy of the Factory Service Manual to fully understand the procedure.
pros+
Now cons-
pros+
Now cons-
There isnt any difference between what you did with the clutch on the civic and the auto on the TL (other than weight) There is NO need to rent storage for anything. ALL you need is a (2 is better) floor jack and some jack stands.
Helms manual is best. A search of the forum will give you the DL link to down load it.
guyenacurazine (08-30-2014)
update on my tranny: identified another local tranny shop (in bay area, peninsula, called "redwood city transmission") that will replace honda tranny into my acura-tl-s for 660$. Previous one I contacted were some nugger who will not consider replacing with another tranny. (posted earlier). Now I just need to find the actual BAYA/MAYA transmision. I have been away so long time, I barely remembers the AV6 tranny code.
Also on another thread, soeone posted make sure not to use torque converter from the acura tl tranny, any other hints would be amazing.
