Transmission problems. Help!!!?
Old Mar 27, 2017 | 08:09 PM
Josephcoxwell's Avatar
4th Gear
I've got a 1999 Acura TL 3.2. When I put it drive it won't move. If you sit there in drive sometime it will catch gear and go until you get on the highway and it won't shift from 2-3. Then just sitting parked with car in drive it jumps and goes out of gear. Check engine lights was and computer said it was the shift solenoid so I replaced it and cleaned the filters. Check engine light went off but still no luck. It continues with the same problem. Sometime when I put it in reverse it makes a loud clicking noise. Someone please help with a solution if there is any. Thanks
Old Mar 27, 2017 | 09:05 PM
Skirmich's Avatar
Hi and Welcome!
First of all how is the ATF Looking? Brown, Dark? or Cherry Red?
Your symptoms seems correct with a Solenoid Malfunction you could help us out if you can provide the Exact OBDII Code so we can help you further.
The Reverse Clicking noise is pretty common on Honda transmissions they are just loud when engaging reverse no worries.
Old Mar 27, 2017 | 09:08 PM
4th Gear
Obdii
How do I find out what the code is?
Old Mar 27, 2017 | 09:09 PM
4th Gear
Atf
the atf is kind of a cherry red color
Old Mar 27, 2017 | 09:14 PM
OBD II reader.
It may also be your axles.
Old Mar 27, 2017 | 09:16 PM
4th Gear
Axles
How do I check the axles. Sorry. I'm no mechanic. All of this is new to me.
Old Mar 27, 2017 | 09:22 PM
Jack up the car and put it on jackstands and then check the boots CV boots for rips and slightly tug on the axles themselves for play.
Old Mar 27, 2017 | 10:28 PM
barnett468's Avatar
wipe some on a white paper towel . it should not have a brown tint to it.
how many miles on the trans fluid?
what brand is it?
did the prob just start or has it been this way since you bought the car?
how did it shift prior to this occurring?
exactly which solenoid did you buy?
