transmission
Old 06-18-2019, 04:30 PM
Gustavo Venegas's Avatar
Wink transmission
Guys im on the proccess of rebuilding the trans on my 2000 has any one purchased the friction plates and rebuild them self's???? please advise!
Old 06-18-2019, 05:24 PM
Received 8,597 Likes on 6,640 Posts
don't bother.. replace it with an AV6 transmission
https://acurazine.com/forums/second-...n-swap-905115/
The following 2 users liked this post by thoiboi:
MaxBeast4Z (07-04-2019), whitetiger5 (06-19-2019)
Old 06-26-2019, 09:40 PM
eksine's Avatar
I have. not sure if they sell Raybestos GPX friction disks for your transaxle but if they do use just the friction disks. GPX usually are sold in transtec kits so it won't say raybestos on the rebuild kit. do not use their steel plates though they are too rough it will tear up your friction disks faster, buy OEM plates or check to see if your old plates are still usable, if you wanna be cheap. watch my videos on 2002 odyssey how-to rebuild transmission. basically assemble the plates and friction disks and put your end plate on it and put the circlip back on the clutch assembly. measure your end play. it should be almost nothing, literally a fraction of a mm. my videos should explain it all
Old 07-08-2019, 10:39 AM
8th Gear
Newbacon's Avatar
Just installed mine on my 2000 TL. As far as the rebuild I thought it was a bit easier than my 4R100 but that's a much bigger transmission. Just installed it last night and had a couple of issues I am working on now but I can update you once done.
Old 07-10-2019, 01:36 PM
8th Gear
Newbacon's Avatar
Talking
Well with about 200 miles so far on the rebuild all is well. Have to get to the slightly different shifts with the shift kit installed but other than than no slipping and shifts like it should.
whitetiger5 (07-10-2019)
NighthawkBlue
2G CL Transmission Recall Q & A
141
05-12-2016 10:16 AM
tommyt1777
12-25-2009 08:38 AM
earthbound741
09-30-2009 04:34 PM
paliknight
09-15-2008 01:42 PM
sonicleo
03-26-2005 11:08 PM
Quick Reply: transmission
