Trans Fluid Question
Old Jan 9, 2010 | 02:46 PM
NJMelissa's Avatar
3rd Gear
I just bought my 2000 TL used. It;s on its second transmission with 60 K on it. I keep reading that the fluid should be drained an refilled to make sure the trans runs at top shape. How much does something like this cost? Can I do it myself being a novice?? Can I go anywhere to get it done??
Thanks for your help!
Old Jan 9, 2010 | 03:00 PM
juanclopez2786's Avatar
id just buy the fluid (ATF-Z1) direct from acura or honda whichever is cheaper and bring it to get changed when you go for an oil change. i wouldnt trust most shops to go out of their way to get you the ATF-Z1 from the dealer just for a quick drain and fill.
Old Jan 9, 2010 | 03:02 PM
niju321's Avatar
more experienced people will weigh in on this, but DO NOT put in anything other than the Honda/Acura ATF-Z1 fluid (a lot of shops will put in random generic fluid that is death for your transmission). changing the fluid yourself is pretty simple. DO NOT let anyone "flush" the transmission, drain and refill only.
Old Jan 9, 2010 | 04:05 PM
WhereUbinh's Avatar
buy the fluid at a honda/acura dealer. 3 quarts should be around $25. there is a diy somewhere. it very simple even i could do it
Old Jan 9, 2010 | 06:25 PM
01tl4tl's Avatar
The skill level of an engine oil change- even easier in some respects
Drain is marked ATF and so is the filler bolt
Buy a set of plastic car ramps and do your own services
IlliniAcura
Sep 19, 2015 09:31 PM
datadr
Sep 12, 2015 09:12 PM
nash3222
Sep 10, 2015 09:46 PM
jfman55
Sep 5, 2015 02:55 PM
