Trans Filter
Old Nov 25, 2016 | 11:45 PM
r_2016's Avatar
Trans Filter
Hi,
I have an 00 TL that has a transmission leak on the top of the transmission. Thoiboi advised me to check the transmission filter, since it is leaking in that general area. When I cheeked, I found that the end of the filter is kind of deteriorated, so I plan to change that out. I also suspect that the solenoid right below that filter is leaking as well. I found a new gasket online for $6.00, so I plan to just go ahead and change it. My question is 1, does anyone know the size of the bolts (6) that hold on the solenoid? The bolts look like some of them might need to be replaced. 2, when I put the new gasket on; should I put high temp rtv on the gasket, or just dry? 3, is it common for the solenoid to leak? Thanks
Randy
thoiboi
Old Nov 27, 2016 | 11:41 AM
01acls's Avatar
10mm, dry, no.
Old Nov 27, 2016 | 11:43 AM
01acls's Avatar
10mm not sure what the pitch is, dry, no.
Old Nov 30, 2016 | 02:41 AM
r_2016's Avatar
Thanks guys
666wokker
Apr 15, 2026 03:06 PM
drewb71
Aug 29, 2016 08:05 AM
4strokes
Jul 26, 2016 06:36 PM
Xanthous
Feb 15, 2016 12:08 AM
bindermike
1G RDX (2007-2012)
Jan 16, 2016 04:55 PM
