Tranny - Is this normal
Old Jun 1, 2004 | 10:19 PM
baddawwg's Avatar
So now that it's getting warmer out, I noticed that the Tranny is acting differently. Going slowly up a hill it seems like the Tranny is letting itself get locked into too high of a gear and instead of downshifting, will lug the car up. It's almost as if its lurching/shuddering because it doesn't have enough torque for the gear/speed/grade. I think on occasion, I hear what sounds like a slight grinding sound under similar circumstances, but without the lurching/shuddering. Only problem is it is not duplicatable, and certainly not duplicatable near either of the Acura service departments. Our subdivision is quite hilly. I know gear hunting in Automatic Trannys is not uncommon. Is it common in the TL?
I only have 55K miles on the car (but a 2000). I believe Acura extended the warranty on the Tranny to 100K miles, but I don't recall the year limit. I have warranty until 62,500 because I bought a certified used. If I let it run past I want to make sure it's covered.
Thanks.
Old Jun 2, 2004 | 03:05 AM
`ill*tl's Avatar
'99-'02+early '03 tl trannies are covered for 100k. I think you're talking about the bumper-to-bumper warranty.
Old Jun 2, 2004 | 08:00 AM
69ssrscam's Avatar
2003 SSM TLS
Unfortunately this sounds like a tranny in a 3.2 TL thats on the verge of a meltdown, which, since you asked, is normal for the 3.2 TL. Acura should be ashamed.
Old Jun 2, 2004 | 11:14 AM
sjdb1's Avatar
These are similar to the problems I encountered before my tranny died. And no, the dealer couldn't find any problem.
Until it started shuttering so bad at 40mph. I made the service manager drive with me for an hour.
Got my tranny replaced finally.
Old Jun 2, 2004 | 11:26 AM
goldendragon576's Avatar
TL-S driver
whatever you do, do NOT let them tell you it's tranny fluid or whatever. Acura Ramsey in NJ tried to charge me to flush the tranny, after they did (i didn't pay) they said it was just dirty fluid and refused to change the tranny. 2 days later my tranny died and I was lucky enough to be able to drive it back home. I never went back to that dealer. I reported them and apparently Acura doesn't really care.
Old Jun 2, 2004 | 11:40 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
i bought my TL from them in January and after i bought it i could not get anyone to help me with my plates or things they said they would come through on. then my head unit got locked out and they wouldnt get me the code. they tried to charge me $50 to remove the head unit and they kept trying to tell me that there was no database to retrieve the number from. and the nub of it is, when i removed it to put in my alpine i noticed there was NO code on the back of it. they're a pretty crappy dealership in my opinion. i wonder if you dealt with the same guys i did.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
