Tranny Fluid Return Line
Old 10-02-2007, 11:01 AM
acutee's Avatar
Hi all,
I need to tab into the tranny fluid return line, and I am wondering if you know what end is the return line.
There is a metal tube goes around the tranny casing looking from the top down with a rubber tube bridging the two metal tubes. Do you know which end is the return line. Assuming there is no oil jet installed. Thanks
Old 10-02-2007, 12:10 PM
joseph_99tl's Avatar
the return is the line that comes out the lowest part of the stock tranny cooler.
on the bottom of the radiator.
just follow the lines.
Old 10-02-2007, 12:11 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
The 00 plus dont have that.
Old 10-02-2007, 12:15 PM
oh snap
Old 10-02-2007, 12:20 PM
fsttyms1's Avatar
Oh and what are you trying to do with the return line?
Old 10-02-2007, 12:35 PM
acutee's Avatar
I am trying to hookup a cooler for a long trip with towing.
Any idea which end is the return line on 03 tl-s?
Old 10-02-2007, 12:36 PM
Old 10-02-2007, 02:52 PM
fsttyms1's Avatar
http://www.cardomain.com/ride/184466/21
Do you have the internal or external oiljet
Old 10-02-2007, 03:39 PM
acutee's Avatar
I have the external oiljet. Thank you for the link. I have read his instructions and he did not mention which end is the return line. I wonder if the cooler is a straight through pipe; and if so, it does not really matter where line-in and line-out is.
Old 10-02-2007, 05:56 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
most coolers are directional- just like fancy rotors
The oil needs to go the right direction
You can always cut the line and start the engine- then you can tell right away if its the return or feed line!
Old 10-02-2007, 08:20 PM
fsttyms1's Avatar
If i remember right the line that comes off the top of the trans and goes into the back side of it is the return line. Its been so long since i did it i cant remember. Check your trans cooler. Many aftermarket ones dont have a preference as to which is in and out. If you stand it up and down it wont matter.
Old 10-02-2007, 11:30 PM
acutee's Avatar
Thanks all for the suggestions.
Old 10-03-2007, 12:55 AM
01tl4tl's Avatar
Mine on the truck is old and is marked IN and OUT, so thats what I am basing flow design on. Times may have changed since the 80s- I hide under a rock most of the time~
Old 10-03-2007, 07:34 AM
fsttyms1's Avatar
The one i installed on mine didnt have a direction. Plus if you stand it vertical (both the inlet and outlet facing down) it shouldnt matter
Old 10-03-2007, 09:20 AM
acutee's Avatar
I am getting B&M cooler, and I will find out if it is directional. I think I am going hook it up as the diy link fsttym1 has. I think it is good to mount the inlet and outlet horizontal, I assume it would have less force for the pump to keep the fluid moving smoothly.
Old 10-18-2007, 05:12 PM
acutee's Avatar
For those who wants to add a tranny cooler, B&M 70255 is perfect. I don't use ziptie. This give me the flexibility to put it aside if I need to.
The 4 metal bar brackets work perfect, one bar needed to cut one inch short, and I only use 3 bars. I didn't find a good spot for the 4th one, but it is very sturdy with 3 brackets.
The cooler is bi-directional so you don't worry about that part.
Hoses: Use ONLY 3/8" ID hose. 5' (comes with the cooler) and buy 7' hoses will be plently. .
DON'T use 11/32" hose. A bit too small and hard to work with.
Mounting cooler was easy, just tighing the screws. one on condensor screw, one on steering cooler screw, one above steering cooler screw that has just a hole for you to put the screw through it.
Running the hoses were real easy, below the headlight there is a path run under the battery.
The hard part was removing the 6" hose behind the tranny.
Old 12-19-2008, 11:05 PM
CL-SEXY SIX (=
Harrisonk531616's Avatar
Great info, i thought it was most helpful. I'm about to purchase the BM hi-tek cooler. So where are the supply and returns you tapped into?
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
stogie1020
Cameras & Photography
17
09-30-2015 01:34 AM
Cexarin
09-23-2015 07:43 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Tranny Fluid Return Line
