Tranny Fluid Question
Old Feb 18, 2008 | 06:53 PM
EL19's Avatar
So I am goin to have the SC put in next week and I've been wondering what type of ATF fluid should I use??? The normal Honda ATF fluid or Redline High Temp ATF??? All help is appreciated.
Old Feb 18, 2008 | 07:34 PM
ChrisQ1980's Avatar
hates the winter
I suggest using the Honda ATF, with the cooler. Change it every 10k. Are you on your original transmission, or the 2/05 update?
Old Feb 18, 2008 | 08:46 PM
fsttyms1's Avatar
Honda or Amsoil
Old Feb 19, 2008 | 10:28 AM
EL19's Avatar
i appreciate it guys...im on the 2nd post 2/05 updated tranny...this one seems alot more solid than the last one though
Old Feb 19, 2008 | 04:03 PM
SodaLuvr's Avatar
Honda's ATF-Z1 isn't very good. It has poor frictional properties, poor oxidation, lousy gear wear, etc.
At the same time, I'm not sure what I'd use either, as fundamentally Universal ATFs are impossible:
As a result of raised awareness regarding the proliferation of individual OEM-recommended ATFs, and discussion in various forums regarding the possibility of "universal" service fill fluids, it was decided to study how divergent individual OEM requirements actually are by comparing the fluids performance in industry standard tests.
A bench-mark study was carried out to compare the performance of various OEM automatic transmission fluids in selected industry standard tests. All of the fluids evaluated in the study are used by certain OEMs for both factory and service fill. The areas evaluated included friction durability, oxidation resistance, viscosity stability, aeration and foam control. The results of this study are discussed in this paper. Based on the results, one can conclude that each ATF is uniquely formulated to specific OEM requirements. In addition, the results show that a customer should not deviate from the automatic transmission fluid specified in the vehicle's owners manual.
http://www.sae.org/technical/papers/2007-01-3987
Old Feb 20, 2008 | 11:42 AM
TLMugen's Avatar
I'd rather be driving:
+1 for Amsoil
I've been running it for over 2 years and I haven't had any issues.
Old Feb 20, 2008 | 01:06 PM
EL19's Avatar
im go with the amsoil...looks to be the best choice and have the best reviews...thnx
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
