Tranny fluid looks clean,how often should it be changed?
UB6IB9
My tranny was changed about 1.5 years ago and it has about 15k km,should i do a drain refill?
today- then you wont have to worry
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I would get on a 15k drain 3 refill 3 if i was you.. It cost $25 for the Z1 fluid and is easier to do then oil.!
since you have a rebuilt WARRANTY acura trans- may as well do everything to avoid it going bad
The primary problem is not enough cooling flow to certain parts.
By keeping the oil ~fresh~ the way acura says to- well it certainly cant hurt
UB6IB9
even if the tranny fluid is still clean?
clean doesnt indicate what is happening inside- it should be getting dirty if its working properly
You can take a 4 ounce sample and send for mass spectrograph analysis
That will tell you how the additives are doing and any particulate matter floating around
A certain amount of several things are expected to be there, past those limits,,,needs something done. It can tell if a certain part is wearing and what type material
www.blackstone-labs.com is one source, check the internet for others
I have never seen anyones results on a trans fluid check- just engine oil
Should be able to tell you if 3 qts is worth the time or more needed to do it right
they might say leave it till 30 and change it all then
So 1st- how bout you be first!
for referance- the trans holds approx 7.3 qts total honda atf ONLY (imo)
It will only give up 3.1 of that on a normal draining-the rest is in the torque convertor
When you do a repeated drive, 3qt drain and refill, drive-- you push the rest of the old fluid out of the TC and into the drain area- shifting thru each gear moves the old fluid out of other parts and new fluid replaces it as it too heads for the drain
UB6IB9
under trans- at back edge
Look for bolt with ATF stamped above it
He didn't say he had a rebuilt WARR. Acura transm.- Is that what you got 1st?
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
HeloDown
09-08-2015 06:51 PM
