Traction Control
Traction Control
Anytime I hit a pothole or after driving for a while my TCS light comes on. Does anyone have this problem? Any solutions? my car is out of warranty so a trip to Acura Dealer would be costly. Thanks
Not that simple - what type of pothole are you hitting - size? depth? Speed of travel? Do you feel you are losing traction? TCS will come on when you are losing traction.
As the light goes away afterwards then yes it's working as it is suppose - however additional information is needed to help you out....
OR you can go to autozone pepboys etc to see what error code comes up!
Or you could have a combination of issues 1) TCS is working as it should 2) you have a loose sensor....
Originally Posted by 03CoupeV6
It only works up to what, 18mph, and it can't seem to control wheelspin anyway.
I get one of the lights pop up when I hit certain bumps in my area (and I do feel it slip). Not sure if it's the TCS or the VSA....never really read up on it. This is my first car with any type of "assistance"....kind of a weird novelty.
Originally Posted by Southern
For any TCS to work worth a damn needs drive by wire to allow the computer to ease off the throttle and apply the brakes as required.
Originally Posted by fsttyms1
Not true at all. the system in my dads ol aurora and caddy worked awsome. You could stand on the gass pedal on a snow covered road and teh car woudl just plain go. The TL well you would get stuck. His old cars woked on the HWY where its most usefull, The TL, well only up to 18 Who teh HELL drives 18 mph and needs TCS???????
Originally Posted by fla-tls
That's what the TL's second throttle valve is for.
I would like to know how GM is handling traction control without a drive by wire system.
Hmm - that may be a TL-S/VSA only feature. I wasn't sure if the TL-P had one.
The TL-S has a second throttle plate in front of the actual throttle which is actuated as part of the VSA system to "let off the gas".
My point was that it was a way of having that type of system without drive-by-wire.
Yeah - I guess it's a TL-S/VSA only thing. Here's a picture of the setup:
The VSA throttle is item 9.
Are we sure that the TL-P's can cut fuel? My 02 TL-P seems to ONLY modulate the brakes. I can floor it on a slick surface and it will feel like ABS working till 18mph and then TCS will cut off, leaving the car to spin freely. It does not seem to be able to control the throttle at all.
Edit: My 05 Accord EX-V6 TCS is a different experience. Its engine bogs down when TCS activates, and I can actually feel it cutting the throttle.
I suspect that since the TL-S cuts off the air, the traction control control works better.
The manual says TCS will pulse the brakes on the offending wheel...it's only meant to assist you when accelerating from a stop or going up a steep hill in snow/ice/gravel (in which they expect you to be driving slow).
My 2002 definitely only brakes the wheels, it does not cut the ignition/air/fuel or anything. It can't control wheelspin and finally just gives up. My Accord, on the other hand, has drive-by-wire and if the tires start spinning out of control and the brakes can't control it, it feels like the engine shuts off.
Looking through my Acura service manual it appears there are two different types of systems.
The TL-P utilizes the ABS/TCS control unit to send a brake signal to the modulator unit which applies brake pressure to slow the spinning wheel, and at the same time a engine retard signal (if necessary) to the PCM to prevent damage to the transmission. Apparently the transmission is capable of damaging itself.
Note the engine retard signal is only sent if damage to the transmission is possible.
The TL-S utilizes the VSA (Vehicle Stability Assist) control unit to send a brake signal to the modulator unit which applies brake pressure to slow the spinning wheel, and at the same time a traction control signal is sent to reduce engine power via the TCS control valve (second throttle). The VSA also has more sensors such as a wheel sensor, steering angle sensor, lateral acceleration sensor and yaw rate sensor. So it is capable of oversteer and understeer control as well as low speed traction.
Originally Posted by pmptx
My 02 TLS has had the VSA light come on when I am less than smooth with the throttle off a light. I assume it is sensing impending wheel spin, because I never lose traction. Wierd.
well not that you know of. All it takes is for the sensor to detect that one of the front wheels is spinning at a slightly faster rate than the rears (something that you wouldnt always be able to tell)
adreano17
09-29-2015 08:48 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
