Torque question
Old Jan 24, 2004 | 08:32 AM
seahawk's Avatar
Torque question
When rotating tires , the manual says to tighten the lug
nuts with 80 ft./lbs torque. , and to take it to an authorized
dealer to have this checked . Now , apart from the obvious
reasons why lug nuts have to be tight , to have even
pressure of 80 ft/lbs, is this to prevent or cut down on
rotor warping?
If so , it might be good to invest in a torque wrench.
Just a thought.
Old Jan 24, 2004 | 08:52 AM
ChucksCL-S's Avatar
Eveness is the key I think to preventing warping, along with not too excessive torque.
Old Jan 24, 2004 | 08:54 AM
njtls's Avatar
i tighten down to 100 ftlb ive been taught that 80 is for steel wheels..and 100 is for aluminum
Old Jan 24, 2004 | 09:14 AM
ChucksCL-S's Avatar
No use 80 on our cars.
Old Jan 24, 2004 | 11:41 AM
Anyone know what torque should be applied to the braking components? I'm doing my rotors and pads today.
Old Jan 24, 2004 | 12:33 PM
goldendragon576's Avatar
TL-S driver
80 on our stocks but 100 for aftermarket wheels.
Old Jan 24, 2004 | 02:07 PM
I'm talking about the calipers, do you know how much they should be tightened down?
Old Jan 24, 2004 | 04:41 PM
njtls's Avatar
why only 80 on stocks but 100 on aftermarket...is their something different with the stocks?
Old Jan 24, 2004 | 05:58 PM
fsttyms1's Avatar
just make the brake bolts tight. it wont hurt them
Old Jan 24, 2004 | 06:04 PM
Southern's Avatar
49N-m (36lbf-ft)
Old Jan 24, 2004 | 06:39 PM
Vicman17's Avatar
I saw a chart in Costco Auto Center showing the TL (aluminum wheels) to be torqued at 80 ft/ lbs. A friend of mine said it's pretty standard on aluminum rims.
Check out Tire Rack, they have a good set (1/2 drive with 3/8 inch adaptor) for around $30.00. Even comes with a plastic case. That's where I got mine. Good investment. Also get a 19mm deep socket from Sears (lifetime warranty) for your lugs.
Saving up for a Jack set (withstands) and compressor for the spring.
Old Jan 25, 2004 | 02:34 AM
Southern
Thanks bro
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
gnuts
Sep 11, 2015 10:07 AM
NetGnome
Sep 7, 2015 08:33 PM
