Top Speed
Old Mar 12, 2010 | 07:25 AM
velvetlevel's Avatar
Question Top Speed
Hi everyone! i was always curious to ask other tl owners about top speed on tl: see i have 2002 tl that hardly go to 90MPH (and only after putting all new tires,full ballansing and alignment!) before that it was 70.. and another 1999 thats flys to 90 in no time but then moves slowly to 100 and that's it. so is that normal for these cars? thanx
Old Mar 12, 2010 | 07:32 AM
fsttyms1's Avatar
You are new, so i will say familiarize yourself with the search button. But to answer your question the cars computer will shut it down at 149.
Old Mar 12, 2010 | 08:59 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
I found myself alone on a nice stretch of interstate last night, and got my 03 TL-S up to 105 with no problem - barely at 3,000RPM on the tach. I could have easily gone faster, but didn't want to miss my exit. That's my fastest in this car thus far, but I've only had it a couple of months.
Old Mar 12, 2010 | 10:17 AM
01tl4tl's Avatar
your car should be a rocket thru 100 and climbing
barely goes 90?- ck plugs- egr port pluging- tune up parts etc
Old Mar 12, 2010 | 10:40 AM
i'm new,and i didn't find anything thru search button,i tried different entries that might relate to speed issue. i did egr port yesterday,new cat. belts eng mounts(tho that's pretty irrelevant). all the same. i had excelaration problem with my M5-and that was the air sensor meter-once replaced fixed the problem,but tls don't carry such a thing(according to autozone and online part stores). both cars run drive,idle and shift smooth as butter.
Old Mar 12, 2010 | 01:17 PM
jdjohn84's Avatar
What are your RPMs at 90? Is it working hard at that speed?
Old Mar 12, 2010 | 01:36 PM
01tl4tl's Avatar
spark plugs NGK Iridium, air filter good? all the normal things checked?
with new cat,, there may have been an O2 sensor issue? ckecked?
try an ECU reset- wont hurt and might help
remove CLOCK fuse on passenger side of cabin for a minute then reinsert
thats the secret backup power to the ECU
Old Mar 12, 2010 | 01:56 PM
assclown's Avatar
2000 acura tl FPR
i think this is the first time i've ever seen you post in a thread like this not mentioning seafoam
Old Mar 12, 2010 | 01:59 PM
ANC297's Avatar
Bonki' Ehrite!
lmao....
So does the computer shut off the fuel supply at 149?
Old Mar 12, 2010 | 02:20 PM
assclown's Avatar
2000 acura tl FPR
i think it's 147, 2mph slower than the V-rated tires (149MPH) are maxed out.
Old Mar 12, 2010 | 05:05 PM
fsttyms1's Avatar
The ECUs are lazy sometimes. My TLp i was clocked at 154 by radar where my tl-s with the 6 speed is actually slower at 148 though it gets there A LOT faster. If i could find a way to get rid of it id do it in a heart beat.
Old Mar 12, 2010 | 06:50 PM
assclown's Avatar
2000 acura tl FPR
maybe you can pay richiev6 a buttload of money and he can find a way to get around it
Old Mar 12, 2010 | 07:11 PM
nhn23's Avatar
I live in
you have a tl-s 6sp? SINCE WHEN?!
Old Mar 12, 2010 | 07:48 PM
assclown's Avatar
2000 acura tl FPR
he did the a2 swap when he did his 6mt swap
Old Mar 12, 2010 | 10:32 PM
01tl4tl's Avatar
AC
seafoam wouldnt hurt~ but I wanted to hear why tires and alignment made it go from 70 to 90 top speed ---get a feel what the larger issues are
Seafoam will clean crud and a lot of techs use it to get a baseline running condition then be able to troubleshoot driveabilty issues
Was the egr port cleaned by removing the intake manifold?
all bolts torqued exact spec?
a vacuum leak anywhere will cause big problems and the car to idle poorly
On the motor mounts- some years have a vac line to front and rear mount- if not connected...vac leak, or if poly mounts used must plug vac lines
Old Mar 12, 2010 | 10:56 PM
fsttyms1's Avatar
Um since around feb or 2006
https://acurazine.com/forums/2g-tl-1999-2003-98/6-speed-conversion-591872/
Old Mar 13, 2010 | 01:21 PM
niju321's Avatar
mine goes to 120 pretty quickly, and i have a tl-p...after that it doesn't seem to do much though
Old Mar 15, 2010 | 12:17 PM
gold2003tl (90)'s Avatar
2003 TL-p
i find myself doing 90 by accident a lot, something is wrong. i good seafoam and a fuel injector cleaner in the gas should help. also a new air filter.
Old Mar 15, 2010 | 01:01 PM
TouringLow's Avatar
does resetting the ECU default all of its air/fuel mixture ratio...if it had deterred from factory settings?
Old Mar 15, 2010 | 02:58 PM
LivingTheLegacy's Avatar
I've got my 03 Tl Type S to 134, it was smooth and i had 1 hand on the wheel. I love hondas lol
Old Mar 15, 2010 | 04:34 PM
mydirtygirl's Avatar
my 03 type-s gets to 120 no problem. once i get there no more action...
Old Mar 21, 2010 | 09:17 AM
i think one (or more) of the wheels were out of balance so it went nice to 70 after which it would shake. so after performing all that i can safely go to 90 but now the gas pedal allmost on the floor but there's no excelaration going on.and like i said before: two of my tls the same way tho one of them had very recently done egr port cleaning,seafoaming and new engine mounts and ecu (radio chip taken out) and nothing changed. the only thing i didn't actually do are the sparkplugs. could they influence the car that much? thanx everybody for all the help,guys!!
Old Mar 21, 2010 | 09:24 AM
and the rpms @90 about 3k may be 3.2 nothing out of ordinary. what i was thinking could there be like an ecu lock that would prevent the car from going faster?
Old Mar 21, 2010 | 09:28 AM
fsttyms1's Avatar
Explain this (in bold)??
And no there isnt a ecu lock at 90. Our ECUs dont have replaceable chips, and reprogramming them isnt really something that can be done.
Old Mar 21, 2010 | 10:40 AM
that's what i mean to say about the ecu. P.s. o2 sensor and cat done no difference
Old Mar 21, 2010 | 11:52 AM
05AcTL's Avatar
ive done 152 in my 05 and do 100+ everyday on my way to/from work
Old Mar 21, 2010 | 11:58 AM
Bearcat94's Avatar
AZ Community Team
Mine's "only" been to 115.
Coincidentlly, within 12 hours, a tire blew out. Glad that didn't happen at 115 mph. Not saying that one caused the other. I am saying, better safe than sorry.
Old Mar 21, 2010 | 01:09 PM
01tl4tl's Avatar
thats the thing I always say about high speed-
Do you know what to do to control the car in a tire blowout situation at speeds above 100 120?
If not- get some track day instruction before going more than 80
otherwise an exciting experience may occur~
Old Mar 21, 2010 | 01:27 PM
Ghostface's Avatar
Bravehearts
I've gone 140mph in my TL-S with no problems at all. It shot up from 60 to 140 in no time. Going 140 feels like ur doing 100mph. Although ur steering wheel gets very lite.
Old Mar 21, 2010 | 05:55 PM
jaMezBOI's Avatar
philly flickin'
I've hit 233km/h acouple times and was stopped by the ecu everytime...
Old Mar 24, 2010 | 09:51 AM
heavyjdaman's Avatar
Mostly Stock For Now
140 in my 02.
100+ on a daily basis
Old Mar 24, 2010 | 10:21 AM
assclown's Avatar
2000 acura tl FPR
in my younger days on my way back to virginia (where i was stationed) from kentucky it was broad daylight and I-64 was clear in morehead KY there was a mercedes (dunno the model) and him and i were playing around, the highest i went was 135 and still was going well. dunno why i didn't go faster cause i certainly could, i guess i was lucky i didn't get caught or noone got hurt.
Dec 7, 2020 05:39 PM
Aug 15, 2019 12:58 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
Sep 17, 2015 10:16 AM
