took my car in for service
Old Oct 13, 2004 | 02:08 PM
car_lost's Avatar
and this is the list of stuff being replaced:
throttle body (idle was fluctuating, i thought it would be either the o2 sensor or IACV but i guess not)
transmission along with oil jet (surprise surprise)
timing belt recall (never had it done so i figured why not)
rubber windshield trim (it was starting to come out of place from the sun i guess)
shiny black trim around windows (both side had wrinkles... takes 3 to 4 days to fix)
dashboard (it warped from the sun were the vents by the windshiels are. i could see the
yellow foam underneath the black material)
both front seat rails or w/e it is (both front seats would squeak everytime someone moves)
right rear speaker (it was blown... go figure how a speaker would blow on a stock system)
battery (i made the appointment to take it on on a tuesday and the battery died the next day)
new rotors and pads (surprise, they warped yet again for the 3rd time)
and thats all i can think of for now... PS.. ALL of it is covered.
Old Oct 13, 2004 | 02:10 PM
car_lost's Avatar
oh and i dropped it off on the 7th and they said i should have it back by next week... probably towards the end... i miss it like crazy
Old Oct 13, 2004 | 02:23 PM
Beeza's Avatar
1 B3AKOHE
A picture of her in your wallet might help
Old Oct 13, 2004 | 02:28 PM
car_lost's Avatar
it doesnt
theres a 90% chance i might get wheels too but i need to test fit them before i commit to buying them and i cant do it till i get it back and i want them badly!!
$875 for 19" axis s7en mod's with two new 235/35/19 and 2 used (about 50% tread left) 225/35/19
Old Oct 13, 2004 | 02:44 PM
dnd2984's Avatar
what year is your car. My dash is lookin wavy to I didnt know it was under warranty
Old Oct 13, 2004 | 03:06 PM
car_lost's Avatar
its an '03. there is NO reason the dashboard should warp.
Old Oct 14, 2004 | 03:13 AM
pimpravi's Avatar
I pimp an Audi A4.
hahahha damn ur car was fuked up
Old Oct 14, 2004 | 08:33 AM
mkeevil's Avatar
I have had my car in for service 12 times in the last 3 months.... There favorate saying it "The car is supposed to sound like that"
Old Oct 14, 2004 | 09:04 AM
kman156's Avatar
i believe there was a recall on type-s t-body's
the idle control motor/ valve was sticking? are 99's supposed to get this oil jet?
Old Oct 14, 2004 | 09:10 AM
car_lost's Avatar
thats what i thought, but the service writer said its the trottle body so they ordered a new one.
im not sure if the 99's are supposed to get the oil jet. i got the recall letter for that last thursday.
Old Oct 14, 2004 | 10:56 AM
stiletto's Avatar
That seat squeak could be the seatbelt fastener... when you get your car back... if it still squeaks, try riding w/o your seat belt and see if the noise persists...
Old Oct 14, 2004 | 11:52 AM
fsttyms1's Avatar
and what sound are you complaining about?
Old Oct 14, 2004 | 11:56 AM
car_lost's Avatar
i've tried that before and it squeaks regardless of the seat belt. i have also used wd-40 on it before but that only fixed it for a little bit. they also "re-tightened" the bolts because supposedly the seat was loose the last time i went. so this time they are replacing the seat rails or something.
Old Oct 14, 2004 | 01:41 PM
mkeevil's Avatar
Well first, when my car was idling the whole car would shake, and they told me it was supposed to do that... then I went back and sat the guy in the car and said if a car is supposed to do that then you can have the car back, they replaced 2 parts and then the car idled fine. Then there was a scrapping noise coming from the front tires and they said that was normal... then braught it back again complained to a differnt guy and they ended up telling me that my routers where warped... fixed them and the noise went away. I took my car in the other day because the road noise seems to be getting louder and louder and when I go around bends over 30 miles an hour, you can hear a bump bump bump sound... I only have 17's but they are Racing Tires...they told me it was my tires because they have an aggressive tred..... I am going to go to my friends shop and switch my tires and check for myself though, because I don't know if I can believe them
Old Oct 14, 2004 | 03:42 PM
fsttyms1's Avatar
first off id say find a different dealer, and 2nd the higher performance the tire the more road noise it will make. and as they wear they will make even more
Feb 25, 2020 09:57 AM
cm561
Jan 27, 2016 10:17 PM
Zonian22
Nov 14, 2015 01:20 PM
lland
Oct 4, 2015 04:47 PM
