TL vs. TL-S ?
Old Mar 5, 2012 | 05:41 PM
Msouza91's Avatar
Exclamation TL vs. TL-S ?
Hey what's up everyone, I recently purchased an 03 "Type S" from some guys and i'm having a real hard time trying to figure out if it's a legit "S".
-I Checked my engine cover and it has the bottom plastic that states type s and it's red writing, but the middle piece is missing.
- Car is debaged so that doesn't help out either
- Has the type s shift knob
anyone with inputs on how I can tell the difference?
Old Mar 5, 2012 | 05:47 PM
Edward'TLS's Avatar
6G TLX-S
2G Type-S has the following that non-Type-S doesn't :
VSA warning light in the dash display panel,
front seat headrests with a hole in the middle, rather than solid,
perforated leather seat covers.
Old Mar 5, 2012 | 07:46 PM
HairyMonkey019's Avatar
white faced gauges rather than black
type s
http://farm4.static.flickr.com/3192/...c90d19eb_o.jpg
non type s
http://carphotos.cardomain.com/ride_...3153_large.jpg
if u look at them, u will notice a big difference
just focus on the engine itself
Old Mar 5, 2012 | 09:17 PM
shiznut123's Avatar
Did you get a carfax when you bought the car? That will show if it's a type-s or not also.
Old Mar 5, 2012 | 09:20 PM
03tLsNBP's Avatar
MechEng
should have J32A2 engraved somewhere on the engine block.
Old Mar 5, 2012 | 09:23 PM
mY sLOW UA6's Avatar
^^Dont they have it on the serpentine belt, if it is the original of course. Don't quote me I could be wrong.
Old Mar 5, 2012 | 09:30 PM
ParaSurfer1979's Avatar
The redlined of non-type-s was 6300rpm vs. 6900 for type-s.
Old Mar 5, 2012 | 10:39 PM
ProjectAcuraTL's Avatar
your interior moldings should be like a dark gray with black and not wood grain brown
your cluster should be whitish silver
on the front of your engine block should have a stamp that says J32A2 and not A1
Old Mar 6, 2012 | 04:20 PM
Msouza91's Avatar
sweeeeet I have all of that! im pumped wouldnt mind the regular tl but this makes me more stocked haha
Old Mar 6, 2012 | 05:33 PM
Did you ever research the car and found out that our cars are prone to tranny failures?
u should be stoked about that
Old Mar 6, 2012 | 10:59 PM
Gabru678's Avatar
lol
dont ruin his fun!
Old Mar 7, 2012 | 01:06 AM
Edward'TLS's Avatar
6G TLX-S
If the tranny really craps out, it ain't no fun.
Old Mar 7, 2012 | 09:24 AM
go ahead to Honda and have the fluid changed to the new DW-1 fluid.
Old Mar 7, 2012 | 10:40 AM
Msouza91's Avatar
It's cool if it fails on me i'll probably look into the manual swap.
Is it easy to change the fluid by myself?
Old Mar 7, 2012 | 02:21 PM
fsttyms1's Avatar
type s
non type s
They are silver, not white.
Old Mar 7, 2012 | 05:40 PM
Meh. toe may toe, tuh mah tuh
Lol
Old Mar 10, 2012 | 11:33 AM
Type War's Avatar
9th Gear
tons of clones out there smh.....
Old Mar 10, 2012 | 01:03 PM
fsttyms1's Avatar
Lol
Not the same.
Old Mar 18, 2012 | 10:25 PM
Lumpy's Avatar
Doesnt the 02 Tl-s have solid leather seats and wood trim on the door panels?
Old Mar 19, 2012 | 08:23 AM
Rockstar21's Avatar
The Dumb One
All TLs have leather seats.
Old Mar 19, 2012 | 10:18 PM
Lumpy's Avatar
I meant solid instead of perforated.
Old Mar 19, 2012 | 10:54 PM
Karanx7's Avatar
Unregistered Member
No the TL-S has the perforated, while the TL-P has solid. Also, all TL cars have wood trim. However, some TL-S cars have the blackwood.
Old Mar 20, 2012 | 02:47 AM
AZsilverTl's Avatar
Very easy. Drive the car around until it is warm. Park for 5 minutes. Jack up the front and find the transmission drain plug. It is on the driver's side. Can't miss it.
Open the drain plug, drain the fluid. Refill transmission with 3* (not sure it is either 3 or more, check the manual) quarts; I refilled through the dip stick hole. Check the fluid level. Go drive the car for 5 minutes. Drain the fluid + refill. Go drive the car again for 5 minutes. Drain the fluid and refill. Done.
Honda recommends the 3x3 flush as their standard procedure. It is very simple, just takes time.
Old Mar 21, 2012 | 09:05 AM
JDTL-S2002's Avatar
My 02 Type-S has brown wood grain for sure. And interior trim is tan.
Old Mar 21, 2012 | 07:17 PM
Jay Blendz's Avatar
The headrest are triangler on the S-Type and square on the base TL's
Old Mar 22, 2012 | 10:01 AM
S-Type or Type-S? Last I checked we drove Acura's not Jaguars... .
Old Mar 22, 2012 | 03:15 PM
Skirmich's Avatar
Yup my Type-S also is Brown Fake Wood Trim + Tan Interior...
Interior is an Option bud "ProjectAcuraTL"
Old Mar 24, 2012 | 08:27 AM
Luke7's Avatar
WNC Real Estate Sales99TL
Here's a link to the honda/acura web site that states the differences between a regular TL and Type S. It will fill you in on the mechanical specs that are different on our Type S cars. Enjoy!
http://www.hondanews.com/channels/29...4-7c004c34c75c
MetalGearTypeS
Aug 29, 2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Timmy18
Oct 17, 2015 03:58 PM
Acura604
Sep 28, 2015 12:24 PM
UA7_Ando
Sep 28, 2015 07:53 AM
