TL Tune up...
TL Tune up...
I have done a search already on this topic but need more help some of my questions are not answered.
I need to replace a bunch of things I am at 95K.
I know I need to replace
Air filter. (just ordered one K&N for $38 includ. ship)
Plugs (probably Iridium) Where can I get a good deal?
Timing belt (Also where can I get the best deal)
Wires (NGK likely not sure are there better ones?)
Set of brakes front and back need to be replaced I have bendix but I am sure I can upgrade. I have stock rotor plan to keep them.
Mobil One Oil as always with K&N oil filter-( trying out for the first time) just ordered it with the air filter.
What else am I missing?
Let me know thanks.
Let me know thanks.
hey,
plugs probably ebay http://stores.ebay.com/id=26746823&ssPageName=L2
i bought mine from them, pretty good deal i think
timing belt i dont know
i would stick with the stock wires, there was a post before that Honda/Acura wires are the best for our cars
good luck
maruisz
good luck
maruisz
i would replace the water pump and timing belt at the same time.
plugs i would go either denso iridiums or ngk iridiums.
the TL DOSENT have plug wires
just go to www.partsbin.com I think they have good prices on their OEM parts.
I have found the water pump for like $96 incl. ship.
Timing belt is at $44
$140 for both
Which plugs do you suggest is the single or double or quad head type plug any different from each other?
What type of brakes do you suggest with stock pads?
Thanks again.
p.s. What needs to be done for timing belt change? If someone is mechanic savvy how long?
$140 for both
Thanks again.
$140 for both
Thanks again.
$140 for both
Thanks again.
Wouldn't hurt to change out the brake fluid and P/S fluid, check CV boots for cracks/leaks, replace cabin air filter, clean throttle body, replace transmission fluid and coolant (although this would be done when water pump is done), replace accesory belts too, wiper blades, rotate tires, that's all I can think of....
2400 Watts in a TL...Why?
1 Post
TRANSMISSON SERVICE AT 95k km.
You can also check the back of the manual for scheduled maintenence for "normal conditions" "moderate (I think), and "Severe conditions" which is what is says to follow if you are in Canada.
There is a pretty good chart in manual for everything from air filter to timing belt to greasing of balljoints. Not too user friendly but all the info is there.
Got the timing belt for $45 at autozone. The guy working behind the counter used togo to schol with me and said the bet he ordered for me were better than o.e.m.
Also he sggested getting iridium plugs.
Oygen sensor also said should be changed but were like $140 for o.e.m.
Thanks everyone
Thanks everyone
Sorry for the misprint.
I meant The Denso's Iridiums. Are the NGK's just as good or are Denso's better?
Is it true that this TL has no wires?
Should I replace the Oxygen Sensor? Their a little expensive?
yes the tl has no wires. pop your hood and look i like the densos. thats what i have but both are great plugs
im not sure i would replace the 02 sensor unless there was something wrong with it
That's sounds good I thought it was required to change the oxygen sensor's.
Where can I get 100% ceramic brake pads.
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
