TL Trunk load
Old Sep 14, 2006 | 12:03 AM
wasup1357's Avatar
00 TL
TL Trunk load
Hi I am goin down to San Diego from San Francisco, I have a trunk full of clothes and 5 people sittin in the car, the rear side of the car is visibly lower than the front from the distance b/t the wheel and the car that i noticed. I just want to check if this is safe b/c I am going to be driving for 8 hrs and wut kinda tire pressure would i need like this. Thz for any reply and sry im a noob
Old Sep 14, 2006 | 12:44 AM
fsttyms1's Avatar
ive done 3 trips from wisconsin to florida with 3 people and a trunk so full of lugage you couldnt fit a piece of paper in it. you will have no problems
Old Sep 14, 2006 | 01:38 AM
wasup1357's Avatar
00 TL
Should I lower the pressure of the tires tho?? thz
Old Sep 14, 2006 | 02:07 AM
chewi's Avatar
if these are stock tires i would keep the pressure at no higher than 32 PSI.
The reason is b/c you will be having a full load in the rear and you don't want to have too much pressure from all the weight onto the rear tires.
If think it would be dangerous if the PSI is over 32 while driving on the highway for hours b/c the tires will heat up and build up more pressure and stress onto the tires which could (*knock on wood*) blow out a tire.
just drive safely within the speed limit and you should be fine.
have fun!
Old Sep 14, 2006 | 09:18 AM
fsttyms1's Avatar
have fun!
ictually i wouldnt lower the psi at all. that would be more dangerous than higher psi. (as ford will tell you with all the problems they had with the explorer) Keep every thing the way you would normally have it and dont worry about it.
Old Sep 14, 2006 | 11:01 AM
acurabum's Avatar
You should be OK if over a bum your rear fender will not rub again the tire....
If yes you might have a problem 'cause you have too much weight in the back....
Goodluck and have a nice trip .....
Old Sep 14, 2006 | 03:07 PM
Edward'TLS's Avatar
6G TLX-S
You should increase the tire pressure with heavy load, not decrease, because tires will become flatter under heavy load. So you need to increase the tire pressure so that the tire contact patch and sidewall flex remain the same as under normal load.
Old Sep 16, 2006 | 12:35 AM
chilifrost's Avatar
Since we are talking about tire pressure what would be the correct tire pressure on after market tires I have yoko's 225, 18, 40 series tires.
Old Sep 24, 2006 | 02:29 PM
dro_15's Avatar
i wouldn't lower tire pressure either.... unsafe and cost more on gas in the long run due to underiflated tires....and for u with 18's it'll make it easier for you to bent ur rims... u can find the correct pressure on the sidewalls of ur tire
baelim
May 10, 2018 09:53 AM
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
