TL-S Transmission
Is the 2002 TL-S tranmission diffrent from the 2002 TL? Also is the 2002's (either) diffrent from the 2000's? I used to own a 2000 TL and have upgraded to a 2002 EBP TLS, just curious if the tramission is the same or not?
Car and Driver made the following comments during their "preview":
"With more power and torque from the engine, you'd probably need to beef up the transmission. Well, you would if you had the bulletproof reputation for durability that Acura has. Thus, the second-gear clutch-holding capacity was increased, and the torque converter was modified for higher rotational forces."
Whole Article (OLD)
Whole Article (OLD)
MetalGearTypeS
Aug 29, 2016 08:28 PM
joflewbyu2
Oct 8, 2015 11:16 AM
