tl-s tail lights instruction
6th Gear
hi all,
i just got an '01 black tl and unfortunately it comes with the amber tail lights. anyway i just bought red and whites off of ebay and was wondering if there is any instructions on removing the tail light assembly.
thanks
thanks
You need to get under the trunk lining. Look in your manual on how to change a rear taillight bulb, it will have instruction on how to remove part of the trunk lining. Once you see the taillights, you need to remove 6-8 nuts (don't remember the exact number). Remove the wiring harness, and push the tails straight out. Then reverse the steps.
Bulbs aren't high wattages bulbs, natural oil from your hands won't make it burst like the highbeams bulb. Only thing you have to watch out for is the brake light bulbs (7443), the parking light filaments are so filmsy that you probably break them if you don't remove it carefully.
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
