TL Redline
TL Redline
Our TL-P redlines around 6,800 or whatever. What is meant by increasing the redline? I mean u can still go past the redline mark and drive it, even tho is dangerous. What difference would it make to increase the redline, rather than just go past 6800 and redline? I really dont know shit about this. Someone inform me. haha
thanks
thanks
dont worry about it, there isnt much power to gain - if any, once you go past redline. redline is there for a reason, if you abuse it, your engine will not be happy, and you could really f' something up.
Originally Posted by crombie1000
Man I'm glad I didn't buy my car from one of you guys who runs the redline
for TL-P the redline is at 6250rpm, but actually you can hold up to 7000rpm b4 the rev limiter comes in
so it has been designed for that, you can feel the power is still going strong, esp if you have a header~
Redlining doesn't hurt the engine as long as its not abused. True that it isn't much power gain, but the whole point of actually reving so high is to be at a higher RPM at the next gear. Well thats what I use it for (usually done at the track).
Originally Posted by samkws
LOL
anyhows, DONT OVER REV...but its been dynoproven that an Tl keeps producing power after redline.
I personally never let the car rev over 3000-3500TOPS when i drive around.
BUT, when i race, i redline 1st and 2nd but over rev 3rd untill 125 (6500rpm) which is where my 4th ('99 TL) picks up vtec @ 4000RPM (got vafc) and rip away from YOU!
MORAL: dont mess and keep away from redline untill you get a a Forged crank, forged rods and pistons, probably new valve train and some very thick oil....OH, and a suped up tranny
Originally Posted by etxxz
wrong...the rev limiter kiks in at about 7300-7400...ever forget about SS while you're partially asleep with very loud music on?
I thought on the TL-Ps, the redline was 6300rpms, and for the Type S the redline was 6900rpms? The increased redline is one of the reasons Acura sighted for the Type S being faster.
There's a difference between redline and fuel cutoff, redline is the manufacturer's "high end" recommended point where you should upshift. Fuel cutoff is when the ECU says enough is enough and cuts timing to prevent engine damage. In automatic mode, I would assume that the ECU probably auto upshifts at or near redline, while in SS or shifting yourself using the 1>2,D3,D4,D5 modes you may be able to squeeze out a couple extra hundred rpms by revving past redline but not hitting fuel cutoff. Fuel cutoff is a killer if you're doing 1/4 mile racing or racing against someone else.
I'd be pretty surprised if the TL-P's fuel cutoff was 7000rpms, which is quite a bit higher than its redline. Usually like I said, fuel cutoff is only a few hundred more rpms than redline. Case in point, the MY04 S2000's redline is 8000rpms, but its fuel cutoff is 8200 rpms.
I'd also imagine that unless there is a significant difference in terms of the strength of the materials used on the TL-P versus the TL-S, that the TL-P should be able to sustain 7000rpms with no problems. I'm not 100% sure on all the differences between the two engines, so I wouldn't go and test out my theory without checking first
BTW - According to Acura, on the 2000 TL-P, the redline is 6300rpms, and fuel cutoff is 6600rpms. (Source: http://www.hondanews.com/CatID3016?m...&archives=2000)
i have done many times and i am pretty sure the fuel cutoff is at 7000rpm
if i leave at auto it shifts at redline but the SS can hold up to 7000rpm without a problem
Ah, well Sport Shift seems even more useful for you TL-P guys then. Us Type S owners in D5 mode will get up to about 6900rpms before the car upshifts, but fuel cutoff is somewhere around 7000-7200rpms, so it doesn't make a huge difference.
I'm curious how much you would improve or worsen your 1/4 miles times by upshifting the TL-P at 7000rpms each every shift versus doing it at 6300rpms. There's probably some sort of in between number that will get you guys better 1/4 mile times by shifting higher into the rpm range.
hard to say because the max hp and torque is at about 6000-6300 RPM, but by shifting slightly after that, you will hit the next gear that much higher in the RPM range - so might be worth it
"us TLP guys" hahaha, damnit!!!
just a little funfact....
i'm sure you're aware that if you redline a tl in SS mode it'll just upshift.....a 2004 TSX doesn't do that....it just bounces off the rev limiter in 1st and makes the car kick back and forth....isn't that really stupid??
(...i was engaging in a manuver to escape danger....)
The 99 TL does that as well and I don't consider it stupid. It allows me to hold 1st gear when coming onto an onramp. Makes a HUGE difference vs having it automatically shift into 2nd.
i know that coz i did that in a TSX while i was having a test drive
the SS in TL only upshift from 1st to 2nd, afterwards it won't upshift itself
yeah i see how it could be usefull.....i rarely go up there in my TL....only in D5 under WOT once in a while.....i thought it was really funny though....
My 04 TL is much more limiting with respect to the redline. As soon as it hits the red area, it automatically hits the rev limmiter. Im still having a tough time not hitting the rev limmiter because I'm so used to my Type S.
I rip off 7100 RPM shifts in my TL-S whenever I really want to push it. I love how my TL-S lets me go into the red like that since there is still soooo much power left in this engine. My 04 has TONS more power up there too, but even gate shifting into 1st will automatically shift before the red in 1st gear.
OK guys lol you guys that say our rev limiter is 7200 is funny. All because the gauges say that doesnt mean thats what it is.
I had my VAFC2 hooked up and did several tests with it. I put about 10-20 digs with it, every time i gate shifted it would shift at 6990ish. The couple times I wasnt watching the revs i hit 7051 that was bouncing off the rev limiter.
And I assure you the vafc is an accurate measure as it is piggybacking the data through the ecu.
Originally Posted by yunginTL
so how do you increase the redline, n how do you no how far you can go?
vpasla1
Sep 17, 2016 07:24 PM
D-Rob
62
Jan 5, 2016 11:44 AM
EvilVirus
Dec 10, 2015 07:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
. But I only do that at the track
