TL Radio Code help!!! HELP!!
Old Mar 4, 2005 | 04:03 PM
99bluetlwtt's Avatar
I punch in the correct radio code and it says error, I've used this code for a while. What should I do.
Old Mar 4, 2005 | 04:23 PM
Pete's2000TL's Avatar
repunch it in, the 1st time i did mine it wouldnt take. I did it a 2nd time and it worked, Follow the instructions in the manual.
Old Mar 4, 2005 | 04:28 PM
TunedTL's Avatar
Initial D
Radio code should not change if you did not change HU hardware. If your radio is broke, that is another story. If you need a replacement HU, I can send you one cheap.
Old Mar 5, 2005 | 03:46 PM
I have a 6 disk 2003 CD player. I replace my original HU. It worked for while, but the radio fuse blew. When I replace the fuse and punch in the same code it didn't ork no more.
Old Mar 5, 2005 | 04:02 PM
so you replaced your original HU? did you get the code for the NEW HU? or are you using the same code from your original one?
Old Mar 6, 2005 | 01:29 AM
The new code
Old Mar 9, 2005 | 04:55 PM
paulmooney's Avatar
E-mail me if you still have trouble getting a working pin. I have a dealer that helps here in Atlanta with looking up pin codes and there are some bugs in the Acura/Honda web site that you have to work around if you have a dealer that swears he gave you the right pin yet it still doesn't work. I just need your serial number to look it up.
Regards
Paul
http://www.angelfire.com/ga4/99_acura_tl_navi/
Old Mar 10, 2005 | 07:55 AM
paulmooney's Avatar
Sorry but I can't look up everyone's. I'd get a 100 emails a day. I can look up the rare few when there is a problem and your dealer can't solve it. I'd also need the code the dealer gave that didn't work. Contact your dealer to get your code.
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
