TL 99 Stalling Problem! Please help
Old Sep 14, 2012 | 01:03 PM
hugous's Avatar
Question TL 99 Stalling Problem! Please help
I was driving in highway 2 days ago for 15 mins around 60-70 mph and it started to happen. The power shut down for whole car, the radio is dead and all the gauges goes off. However everything comes back in 1 second. Its scary and took me a while to realize that anytime I release the gas pedal or when I brake, the power shut down and came back in one moment. However, when I release the gas tenderly, it did not shut down. I tried to go to school for my class on time. When I finished my school, I came home without any problem like nothing happened before. The day after, it happens 2 times randomly. I tried to release the gas pedal suddenly,etc... but it was just randomly.
I did a little research and found that my car was fixed for the ignition switch 2 times in the recalls by previous owner.
Current mileage is 141000. I just did seafoam 2 months ago when I bought it, I also replace the NGK spark plugs recently.
Has anyone experienced this problem?
Old Sep 14, 2012 | 01:15 PM
MyTL09's Avatar
B A N N E D
Ignition switch electrical portion, THEY WONT COVER IT AGAIN AS A RECALL, YOU HAVE TO PAY FOR FOR IT OUT OF POCKET, ITS NOT TOO MUCH
Old Sep 14, 2012 | 07:08 PM
hugous's Avatar
It gets worse today. Anytime I release the gas pedal, the power shut down. Anyone here has a reasonable explanation how the ignition switch failure can cause this problem?
I gonna replace the ignition as soon as it arrives.
Old Sep 14, 2012 | 10:08 PM
fsttyms1's Avatar
do you have a volt meter or know how to use one? If so test the alternator and battery to see what voltage it is putting out.
Old Sep 15, 2012 | 01:40 AM
01tl4tl's Avatar
parts stores will ck the electrical system for free, as suggested above
They will scan for any fault codes too
Do you get a big yellow `CEL` on dash while driving?
or you may have a bad ignition switch-back part- those die on 99s a lot
at least 3 in the cars lifetime.. average!
parts stores carry them if needed
Wiggle the key when at idle,,any change?
other strange possible: egr system passages and single port on 99 is clogged
recall for that once, then on your own DIY,, like the rest of the years~
ck recall section on owners site for Open or Fixed status on that issue
Old Sep 15, 2012 | 11:14 AM
3.2TLc's Avatar
Hey Hugous, get that problem fixed ASAP, otherwise you may shutdown at a bad time.
Old Sep 15, 2012 | 11:03 PM
hugous's Avatar
Thanks 3.2 TLc, I will get it fix as soon as possible. It happened several times today. Like 01tl4tl said, it shut down several times when I wiggle.
Hope that the ignition is the only reason cause this problem. I found a lot of complaints about TLs stall right after starting for no reason, hope this is not my case.
I also found that there is no official recall about the egr system, should I ask the Acura about this? When I check my VIN, it just appears that there were 3 recalls, 2 of them relates to ignition switch and ignition interlock. One recall is still open for tranny warranty extension (So I guess this is still first tranny..impress ) nothing about ERG recall.
If I cannot be covered, where can I buy the spacer kit?
Thanks guys
Old Sep 15, 2012 | 11:06 PM
hugous's Avatar
Forgot to mention 2 ignition recalls were fixed.
Old Sep 16, 2012 | 10:17 AM
01tl4tl's Avatar
that part on trans is no longer valid--you were part of the covered vins--thats all it means
website doesnt show if trans replaced,,sometimes 800 doesnt know,, but dealer can look it up and know!~
blue paint on bolt heads for trans and things attached to trans are the tell its a warranty replacement
only single port 99s had a recall for egr,,some VINs
call acura care 1 800 382 2238x5,,dont trust the website
stalls after start can be egr clogging too
Old Sep 25, 2012 | 11:53 AM
hugous's Avatar
Here is the update folks, after I replaced the ignition switch, it run smooth for couple days. However, it happened again today, the power shut down and came back just in one moment any time I release gas. I stop and restart it and it stops happening. I dont know when it will happen again
When I open the old switch, it see a black smoke area inside the switch.
Dont know what to do now.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
