Tire Sizes posted by this Site
Old Jan 17, 2002 | 10:52 AM
MikeyB's Avatar
Why is it that our site recommends using a tire for our Stock TL-S Rims that is ill-advised by tire rack. The potenza RE-730 is suggested by our site. When ispoke to tirerack.com, they said this isn't an acceptable size, and is not safe.
Where is our basis for determining that this tire is safe?!?!
tire rack recommends 215or225/50R/17 as the ONLY two acceptable sizes.
I don't know a whole lot about tires and aspect ratios but, i would consider changing our "recommended tire" to a safer one, if aggressive cornering and driving could force the tire to slip off the rim.
Old Jan 17, 2002 | 12:00 PM
Road Rage's Avatar
Not a Blowhole
I think you make assumptions that you might not want to. Tire Rack is a commercial enterprise, and it wants to sell tires and wheels, and minimize warranty and customer service adjustments. The recommendations for the TL reflect those priorities, not those of us on the site. Plus, TR cannot possibly check out all the combos, esp with lowering springs, etc, which Forum members can provide.
I bought from TR, and in fact the stock size tires rubbed against the left rear plastic tab on the rear bumber cover, which I filed off. IMHO, 225/45-17 on a lowered car would be perfect on a 7 - 7.5: rim, and no, it won't "slip off".
Old Jan 17, 2002 | 12:56 PM
jkozlow3's Avatar
But on a 6.5" rim (stock TL-S), you're pushing it.
Old Jan 17, 2002 | 02:07 PM
MikeyB's Avatar
Thank you for the input. don't get pissed when I ask, (but the TLS isn't a 7-7.5" rim) it is 6.5, we(our site) recommends the 45 aspect ratio for the 6.5" rim.
I am merely asking if it is safe to put that size tire on a 6.5" rim. and if so how do you know?
Old Jan 17, 2002 | 04:01 PM
tea elle
Guest
Posts: n/a
good question
Old Jan 17, 2002 | 06:29 PM
EricL's Avatar
Originally posted by tea elle
good question
Going a 1/2" shy on the 7" recommended rim width isn't going to do you in (I would be more concerned about the load rating). There are a number of manufacturers that have put tires on rims that were 1/2" too narrow. (OTOH -- if you ever have a blow-out or other problem, you've "broken" the rules, so watch out!)
When shopping for the 225/45-17, the load rating is 91 SL in most of the high performance tires. The stock tires are 93 XL.
If you go with a non-XL tire and it has a lower load rating to boot, watch the passenger load, temps, and continuous max speed...
The Toyo T1S Proxy in a 225/45-17 has a reinforced casing with a load rating of 94. Most of the max- and ultra-high-performance tires on TireRack will have a load rating of 91 (in the 225/45-17)...
Old Jan 17, 2002 | 06:35 PM
StanMan's Avatar
eric hit the point...i was gonna say you have to be aware of load ratings too!
ron3.7
Sep 20, 2015 11:39 PM
GhostTL09
Sep 19, 2015 01:57 PM
coykiam
Sep 11, 2015 03:43 PM
nuldabz
Sep 3, 2015 05:49 PM
