tire pressures...
Old May 25, 2002 | 12:33 AM
SilverBullet's Avatar
tire pressures...
can someone tell me the recommended tire pressure for this particular set-up:
225 45 17's on type-s rims
i currently have it on 38 psi.
Old May 25, 2002 | 01:11 PM
Bitium's Avatar
Retired MOD
Re: tire pressures...
Sounds good to me. Between 34-38 psi for 225/45 is ideal.
I got 38 psi on 225/40 18's
Old May 26, 2002 | 02:14 PM
NSX4dr's Avatar
Original Member #81
That's too much....you're tire pressure increases as the temperature does....Run at between 32(mfr suggestion) and 35 psi max......
I run 34psi on 235/35/19s
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
