Tire pressure question
should the front wheels have less or more pressure than the back wheels or should they be the same, i know the less pressure in the front the less you feel a bump.....
It depends. Do you want extended tire wear or handling? Personally, I like 35 p.s.i. all around... it's kind of like golf: for most weekend duffers, K-mart balls or Titliest Balata will not make a difference. It's the same with air pressure; you can't/shouldn't drive aggressively enough to know the difference.
Re: Tire pressure question
On my current car I have the pressure up about 6 lbs. each tire. So far these tires have lasted 7 years and 55k miles. Mileage has gone up (less rolling resistance) and they are wearing just as evely as I could hope for. But that's on a 94' Talon with Goodyear RSA's replacing the stock Goodyear GT+4's.
yo on the front tires, on stock '00 rims, i had it at about 40psi and it was way too harsh on bumps, so as of now i've dropped it to 37psi.......b4 i had it at around 30psi on the front and it was swishy on sharp turns
i pretty much run 38 to 40 on all my tires (unless otherwise stated lower max psi) on my current sumitomo htr='s im running 40. with my last set of yokos's i was running 42 (i found to be the best handeling for scca and road course days)
should the front wheels have less or more pressure than the back wheels or should they be the same.....
You may or may not like those consequences. For a more neutral handling state, I would put 2 lb MORE in the fronts.
rw
Blown is Best
Re: Re: Tire pressure question
Originally posted by sparky57
Biasing the front to rear tire pressures will effect the handling state. Lower front tire pressures will increase the natural understeering tendency of front wheel drive cars. That's going to make it handle more like your grandmother's Buick in corners. The car will tend to just plow forward when pushed.
rw
rw
