tiptronic question
tiptronic question
hey i was wondering in a 2003 tl-s auto...is it possible to make it so the car will stay in first and not shift to second on its on, while in tiptronic mode.
as i don't own the same car as u it's just speculation on my part, but maybe if you just put the shifter in 1 it will hold the gear....again just speculation, but works in my 99 (though i know the later years have different transmission logic, my car holds 1st in sportshift also)
No way to change it. Its built into the ECU
gate shift is your only option for 1-2 control
if drag racing turn off TCS
its programmed that way for people who got off the freeway in SS- and forget!
car shifted to 1 at stoplight for them,,turn into parking lots and forget to shift to 2nd and reviing the motor
unless you have a need to run 1st up to redline- use SS and shift when you want
Its not like it shifts at 2000 unless you are in a parking lot and all the sensors agree whats going on
Its hardest on the trans to downshift at high rpm into 3rd and 2nd, wears the clutch pack/disc quickly
1st gear issue-?? this is not your old car~
have you read the owner manual?? free online if you dont have one
it has all the speed limits for each gear and how to properly use all the systems
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
click your year and model- then wait for pdf file to open- save to hard drive or read online
any really hard use of 2nd and 3rd puts wear on the weak point of the system
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
