tips for spark plug removal
13.2@106mph G37 RWD Sedan
i jus had a quick question i just wanna know how is a good way to take off the coil pack connected to da spark plug so it doesnt get broken... and if theres any other tips that might be useful
Make sure the engine is STONE cold!!! You DO NOT want to strip the threads when removing/installing the spark plugs.
There really isn't much to removing the coil packs. IIRC, just disconnect the harness from the coil, remove the bolts holding the coil down, gently pull the coil out. You may have to slightly twist it left/right to break the seal between the plug and the coil. Once you have it out, lay it gently on a stable surface where you won't accidentally knock it over.
definetly a real spark plug socket of some kid, and a foot of vacuum hose to assist in lowering and starting the new plugs safely
Should be something in the DIY on this
Be sure to treat the coils like fine glass thats very fragile otherwise one dies in a month
Suggest seafoam the intake manifold a week or at least a day before plugs- to give them a nice clean home to work in
Use ONLY NGK plugs- Iridium or Platiunum
a dab of plug anti-sieze grease on the threads helps them go in and remove next time
Use a blanket and lean over the fender or engine as needed
For the rear plugs use a 3 and 6 inch extensions, adding pieces as you lower it into the plug recess
Use a short ratchet, and your hand will find a bump in the firewall for them
press on the connection from the wire harness. and wiggle it a bit until it pops off.then take the allen screw out, coil out, spark plug out. be very careful that u dont drop or slam the coils
no cc unit around the spark plugs.one by the abs pump but thats it.
also a lot easier if u remove the stock strut bar.more work and time removing it, but a lot easier and faster to get the coils and plugs out
I didnt remove the bar and it wasnt too bad. I wish I had the Haynes repair manual for my car, but no auto store stocks it
lol i had a cheap socket and it held the plug really tight after i got the first one in with 2 3 in. extensions and got it tight went to pull out the socket then the extensions just came out so i had to remove the plug again then put duct tape around the extensions and socket, lol worked really well and actually doubles as pertection if u hit the wall with the socket since they are deep
Do your front ones first and you'll see that you can do the back ones pretty easily, except the last one on the passenger side. That one is kind of a pain because of the limited space.
cycdaniel
Dec 17, 2019 10:58 AM
pistacio
Sep 26, 2015 09:45 AM
