tint need help
tint need help
im thinking of getting a metallic tint done after having smoke tint on for the past 2 yrs. the problem is that the back window if tinted with metallic will mess with the navigation system. what do you guys think if i just get the sides tinted and leave the back smoke? will it be horrible or what should i do?
Some people claim that the tint effects the navi, I have a metalic tint on my car and haven't had any problems due to it. What I have noticed (and it happened before the tint too) is that if there are two roads very close side by side the navi sometimes places you on the wrong road. Also in NJ it sometimes gets confused since every road intertwines with the next. Other than that nothing.
As a GPS engineer
, allow me to say that any metal in the proximity of the antenna will attenuate the signal and weaken reception.
Whether metallic tint affects gps reception depends on the brand of tint and the metal content of the tint.
FYI: Your GPS antenna is next to your third brake light. It is not at the top of the rear windshield like most people are saying.
FYI: GPS signals are very weak as is, on the range of -160dB on the Earth's surface.
FYI: My "titanium" tint from Pro-Tint does not seem to cause problems with my GPS reception, although it must, at least in part, weaken the signal to some extent.
, allow me to say that any metal in the proximity of the antenna will attenuate the signal and weaken reception.Whether metallic tint affects gps reception depends on the brand of tint and the metal content of the tint.
Tint doesnt weaken the signal any more than the metal body of your car does. Hes right. that little plastic box at the top of the window is where the radio antannae wire connects to the glass antanna
Bottom line, tint with a high enough metal concentration would completely block the GPS signal. So be careful what type of metallic tint you choose and test it out before you have it installed. Have them lay a sheet of the stuff over your rear windshield and make sure you still get a navi satellite signal.
Jul 16, 2017 07:33 AM
