Timing Belt
http://www.acuraautomotiveparts.org/...catdisplay.jsp
belt is like $30.
belt is like $30.
Originally Posted by DEPTLS
what else is done besides the water pump, timing belt, tensioner what else should be changed?? i wana get it most all done while he has to go that far...
At 105K miles also the spark plugs, coolant, radiator hoses, and thermostat should be replaced.
A valve adjustment would be a good idea as well.
totally agree with swalch on this matter- replace everything- its nearly 7 or 8 years old and failure of any single component can cause dramatic expensive engine failure!!
New belts without new tensioners is like putting new tires on and not balancing them,
in my opinion
A valve adjustment will help you in these days of skyrocketing prices-
See the owner manual for complete service schedule- check the 105 for details
here is the free download of manual if you need click year then model
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
oh and my favorite tune up in a can between tuneups.... is seafoam!!
in my opinion
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
asahrts
Sep 4, 2015 05:55 PM
