Time for a tranny drain and fill (amsoil or honda atf)
Old 06-19-2008 | 01:58 PM
dnd2984's Avatar
Well I have about 30k miles on my current tranny, and I need to do a drain and fill.
Would there be a issue if I mixed honda ATF with Amsoil. I really only was going to take 3 qts out and add 3.
Old 06-19-2008 | 02:22 PM
fsttyms1's Avatar
If your going to switch to amsoil i woudl do a complete drain and fill with amsoil and not mix just 3qts.
Old 06-19-2008 | 02:54 PM
dnd2984's Avatar
just do the 3x3 method then.
Old 06-19-2008 | 03:03 PM
6MTUA5's Avatar
No He Can't
I thought we were supposed to use nothing but the Honda Z1 ATF in these?
Old 06-19-2008 | 03:09 PM
sturgeongeorge's Avatar
yeah, does anyone know what you should use during a flush or even a drain and fill?
Old 06-19-2008 | 04:07 PM
dnd2984's Avatar
Ok I am just buying a case of Z1 from Honda. I need to do the RSX and my TL.
For the TL. Take the top bolt off, and drain from bottom. Correct. What tools are need (sizes)
Old 06-19-2008 | 04:10 PM
fsttyms1's Avatar
Dont flush, only drain fill. What do you mean use? as for fluid? Honda fluid. Some have used amsoil. While i dont think amsoil would hurt the trans any i dont know if i would use it.
Old 06-19-2008 | 04:16 PM
6MTUA5's Avatar
No He Can't
Just take a 12mm, 14mm and 17mm and you should be good.
Old 06-19-2008 | 08:34 PM
01tl4tl's Avatar
the trans drain has the letters ATF stamped on the case above the drain.
Some units may use a standard 3/8 drive ratchet drain plug- where the ratchet fits into the squre
- the top bolt on your replacement trans should be 17-19 and says ATF right on the bolt- cant miss it
A ziner recently wrote me that their switch to amsoil resulted in shifting issues and was going back to honda stuff.
I am sticking with honda PS fluid and ATF
Old 06-19-2008 | 11:04 PM
sbuswell's Avatar
I need 2 more gears
I've used amsoil for years and had good success with tranny's. First lasted 143k, 2nd has 25k and it shifts 100% perfect. I'd use amsoil IMO. It's recommended for honda/acura's per amsoil site and they back up their products.
Old 06-21-2008 | 12:35 AM
Why is it not ok to completely flush and refill?
Old 06-21-2008 | 06:36 AM
MikePA's Avatar
Honda does not recommend flushing the tranny. It's been posted here numerous times. Drain and refill only.
Old 06-21-2008 | 08:54 AM
hockeynut's Avatar
Use the Honda fluid - my second tranny went 1 day after switching to Amsoil (no prior symtoms). I doubt that the Amsoil had anything to do with it but I will never have a warm fuzzy with Amsoil in Hondas. Most likely due to draining old dino fluid, putting in fresh synthetic (2x3) and brought problem to the surface.
Now 3rd trans, 187k and drain 3 qts every 10k.
cobra10363
07-23-2024 05:13 PM
mada51589
05-03-2022 09:54 PM
cycdaniel
12-17-2019 11:58 AM
Skirmich
09-15-2015 07:41 PM
Mike Bertram
09-10-2015 10:27 AM
