Time for spray
I gotta thank Pizaul for hooking me up with the kit. I just got it today. hopefully will be installing it sometime this month. Its the Zex wet kit. i plan on runnin a 100 shot. The kit has everything from what i could tell including the purge and bottle warmer. I just have a question about the zex spark plugs, dont i need 6 of them? only the 4 pack was included. Pizaul even included the custom guage and switches
Nice mod man. I'll be interested to see how the #'s come out too. Seems like you guys up there in CT like the spray. I'll be back up that way around Thanksgiving, maybe I'll have to take a look at your setup and maybe you can even take me for a ride. It'll be busy around the holidays, but if you're up to it, I may be able to break away from the family for a little bit. Good luck with the install. You doing it yourself?
Originally Posted by S1CK TypeS
^ i plan on gettin it dynoed as soon as possible. hopefully i can make it to the track before the end of the season. im hoping to run low 13s high 12s.
Originally Posted by Razzi
no mods needed for the bottom end and all that stuff to handle the new power?
Originally Posted by HockeyMan0920
nice. If only you lived down here in Texas...i'll be at the track this saturday and the next. Hoping for a 13.7 if i can shift right. What gears are you going to spray in?
man if i was in TX id be goin to the track with you too. good luck at the track, dont break anything. im spraying in high 2nd off the line and on rolls ill spray in low 3rd
I talked with an ex AZ member (Malingator) this weekend. he was runnin a 100 shot. he told me the motor is forged so i should not have a problem. i dont really plan on goin any higher than that cause of the stress to the tranny.
Originally Posted by WTL-S
Kev when are you going to the track? Ill come down with you I want to run my car to see what she runs as well.
Originally Posted by orgnlprankster7
you should jump in the groupbuy for the innovative motor mounts
my other question is when i spray a 100hp shot is that measured at the crank or the wheels? its at the crank right?
Rajca do u have any dyno #s?
its at the crank
i mounted the bottle in the trunk right behind the rear cup holder so i could open it (still waiting on a remote opener), the zex nitrous management unit is mounted behind the battery and under the intake pipe, ran the line under the car by the fuel lines, still waiting on the bottle warmer and the pressure regulator, and gauge, and the purge kit. will post pics later
dont know how to make the images bigger
pic of the switch, couldnt get a better shot
tapped into the TPS so it works at full throttle
nitrous management unit, still have to paint it black
got the jet behind the sleeve so its harder to find
i did all of this so when someone looks inside my engine bay it all looks stock (and i fool everyone that looks) so it works
ddietz
Sep 9, 2015 07:00 PM
detailersdomain
Wash & Wax
Sep 3, 2015 10:56 PM
