Time to change the Shock!!
Old 05-18-2002 | 11:45 PM
HOT's Avatar
HOT
ok. my 99 TL with comptech spring&stock shock pretty much worn out(83000miles). It seems like the shock can't take any more rough roads. Plus the comptech spring is even LOWER than before!(oh and of course i have body kit too..)
What's my best solution?? I want my ride to be comfortable not rough. should i buy a set like coilover or All stock shock and spring for maximum comfort ride. Is there any other way than going back to all stock??????
Old 05-19-2002 | 12:50 AM
songoku's Avatar
BlingBling INSPIRE 32V
If you can spend some $$, coilover might be good idea.
BTW you have 830000 on your car??? :wow: :wow:
Old 05-19-2002 | 12:57 AM
kman156's Avatar
Exclamation koni yellow gas adjustables!
my 99 with comptech sp/sways loves'em! adjustable for ride firmness. check em out for yourself, you'll get alot of opinions, you already have springs, coilovers at 80,000 miles? $$$$ stick with a good high performance shock, or replace your stock shocks. imho kman
Old 05-19-2002 | 03:21 AM
edgalang's Avatar
Purchased: April 28, 2001
Re: Time to change the Shock!!
If I was in your scenario I'd hunt down all the guys in the board that changed their stock shocks with full coilovers and bid for their OEM ones for cheap.
Old 05-19-2002 | 03:42 AM
kman156's Avatar
Re: Re: Time to change the Shock!!
good idea , but most guys dump their stock shocks, when they upgrade.
Old 05-19-2002 | 09:30 PM
HOT's Avatar
HOT
So how much the stock shock costs anyway?? any1 know? (feel like after market shocks r cheaper than OEM ones)
BTW y does Koni Yellow cost so much than any other shocks??
R they really better than cheaper shocks??
Old 05-28-2002 | 11:20 AM
ATL_TL's Avatar
Can the 2002 stock shocks (either TL-P or TL-S) fit a 1999 TL...I would do that if it is possible....Thanks
mada51589
05-03-2022 08:54 PM
vaughanml2
11-01-2021 10:16 AM
02-25-2020 09:57 AM
merc009
09-14-2015 06:43 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
Quick Reply: Time to change the Shock!!
