Tight Steering Wheel
Old Sep 23, 2010 | 09:34 AM
Feeelax's Avatar
03 TL-S 06 MDX
My steering wheel on my TL-S has been tight since I've bought it. Some told me its actually a good thing but just to clarify things is there something wrong with my steering wheel or wheels?
It gets annoying during turns and it actually causes my arms to get tired on long drives.
How can I go about fixing it to make it smoother and easier to turn?
Power steering fluid?
Old Sep 23, 2010 | 11:45 AM
01tl4tl's Avatar
first ck the tire pressures
then the ps fluid is probably ready for a flush--easy diy
inspect rack boots for leaking inside from bad rack seals
the TL drives like butter, 1 finger on the wheel and it stays on course
Some years have speed sensative steering too, giving more action at parking lot speeds to get in a space and less at freeway to cut down wandering
Old Sep 23, 2010 | 11:47 AM
01tl4tl's Avatar
alignment can cause steering issues too
You recently got the car- it needs to be looked at by an alignment shop for crash damage or worn parts
NOT the big name stores!!!!
Old Sep 23, 2010 | 08:45 PM
Feeelax's Avatar
03 TL-S 06 MDX
yeah I previously owned a 03 TL-P and the steering was so smooth compared to this one..
just bought some power steering fluid at wal-mart today... I'll see how it goes tomorrow. thanks
Old Sep 24, 2010 | 01:03 AM
01tl4tl's Avatar
I hope its good fluid--you know how picky the TL is
Old Sep 24, 2010 | 01:55 AM
dsickles's Avatar
tl premium has a different steering rack than the type s.
tl-p is speed sensitive (it becomes more firm at highway speeds) and the type s has no such system.
Old Sep 24, 2010 | 10:00 AM
Feeelax's Avatar
03 TL-S 06 MDX
Its "Prestone" brand and it says specifically used on Hondas/Acuras right on top of the bottle. anyone else familiar with this fluid?
Old Sep 24, 2010 | 01:23 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Type-S has bigger, heavier wheels (17" vs 16") and wider tires (215 vs 205). The type-S tires are also lower profile and have stiffer walls. I think all those things make the steering stiffer.
Old Sep 24, 2010 | 05:00 PM
Feeelax's Avatar
03 TL-S 06 MDX
btw guys UR pulleys or headers?
Old Sep 24, 2010 | 05:27 PM
01tl4tl's Avatar
you only need the lightweight crank pulley- not the ones for ps or alt,,car will be great with just the crankshaft
if running more than 600 watts stereo, get the stock size lightweight pulley
the rest can run `underdrive` which will slow ac operation at idle but fine the rest of the time- that pulley requires a different size belt to compensate
ck bomz brand--CL guys been on them for years, or excelerate has the UR in stock size
that alone makes the car rev faster, so it gets to vtec faster = faster car with no change in loudness to attract attention~
Old Sep 24, 2010 | 07:39 PM
jdjohn84's Avatar
I ordered a Bomz pulley yesterday off eBay - $50 w/ free shipping. Now I need to get a Honda crank pulley nut tool. I can't find any loaners, so I guess I'll have to buy it just for this one project. Well, I'll be doing my timing belt/water pump at the same time, so I guess more than one project. I'm debating OEM parts vs after market. I know many aftermarket parts are better than stock, and they are cheaper, so...
Old Sep 24, 2010 | 07:51 PM
FirePR2002's Avatar
bringin lead
i see you're in nashville - that's only about 3 hours from atlanta. are you ever down this way?
the reason i ask is we atliens have a guy in marietta (upper northwest side) that will do the timing belt and pully install fairly cheap. might be worth it if you're ever down this way.
Old Sep 24, 2010 | 08:26 PM
jdjohn84's Avatar
Ha...I actually grew up in the ATL, but don't get down there very often anymore since my family moved away. Thanks for the info, though.
Old Sep 24, 2010 | 08:44 PM
Feeelax's Avatar
03 TL-S 06 MDX
hey john. This the one you got? Lmk how it is thanks.
http://cgi.ebay.com/ebaymotors/Bomz-...Q5fAccessories
Old Sep 24, 2010 | 08:51 PM
jdjohn84's Avatar
That's the one. They sent it UPS, supposed to be delivered Wednesday, the 29th. Probably get it installed next w/e along with timing belt and water pump.
Old Sep 24, 2010 | 08:56 PM
Feeelax's Avatar
03 TL-S 06 MDX
i actually just recently changed my belt and pump... but the pulley didnt come to mind.
Old Sep 24, 2010 | 09:31 PM
gold2003tl (90)'s Avatar
2003 TL-p
so any power steering fluid that says it for designed for honda it will work? or do you need to use a fluid from honda like you would buy in the dealer.
because you go to an auto parts store and they have power steering fluid thats for hondas, assuming that will work with our TLs.
Old Sep 24, 2010 | 09:42 PM
jdjohn84's Avatar
Foresight comes with age
Old Sep 24, 2010 | 10:04 PM
Feeelax's Avatar
03 TL-S 06 MDX
haha i'm sure it does.
now its going to be a hassle..
and to Gold2003 the bottle actually says for "honda AND ACURAs" so I think its ok for the TL
Old Sep 24, 2010 | 11:26 PM
jdjohn84's Avatar
Not a hassle. Did you do the other work yourself?
Old Sep 25, 2010 | 12:26 AM
Feeelax's Avatar
03 TL-S 06 MDX
My dad's friend installed the new pump and belt for me during mid august . just last month. So I probably won't be able to install this myself.
Old Sep 25, 2010 | 10:52 AM
jdjohn84's Avatar
Changing the pulley is a LOT easier than the timing belt and water pump. The only trick is getting the crank pulley nut off, but there is a special tool for it. If your dad's friend has that tool...piece o' cake. Of course your dad's friend may try to talk you out of installing a light-weight crank pulley. Some stock crank pulleys are weighted to counteract the turning of the crankshaft itself, and if you replace those weighted pulleys with an unweighted one, the crankshaft will be off-balance and 'creep'. When that happens, it will ruin the crankshaft seals and leak oil. Luckily our cars don't have weighted crank pulleys, so all good.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
IIDXholic
Sep 19, 2015 10:18 AM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
