tie rods....
Old Apr 13, 2010 | 04:00 PM
MurdaZ's Avatar
tie rods....
did some searching on the forums regarding my shaking issue....found out some people have issue with tie rods on our cars so i checked it out..
checked out my steering rack and pinion and the tie rods, and noticed the tie rod ball and socket, i can twist it back n forth about 70 degrees from rest position, with the car on the ground and barely any effort...no cracks in the boot but also noticed when i give the steering wheel a wiggle you hear a knocking noise..., went under while someone was wiggling it and u can feel it on the rack/pinion.....want some opinions if that is normal for it to knock, and is it supose to be that easy to twist/rotate? arent they supose to be stiff?
Old Apr 13, 2010 | 04:33 PM
MurdaZ's Avatar
actually found a video on how it moves side to side, i would say it rotates more than this vid...ignore the last 20 secs
http://www.youtube.com/watch?v=g17SHCKhdb8
Old Apr 14, 2010 | 08:19 AM
MurdaZ's Avatar
bump, cmon anyone got any ideas? any ever change their tie rods yet? i even searched google for more info and barely anything came up....only that volvos are a pos
Old Apr 14, 2010 | 10:39 AM
fsttyms1's Avatar
Tie rods should have the ability to rock like that. Its the up and down and excessive movement that they shouldnt have. Can you make them pop up and down at all? how about wiggle (not the rotating that you can get)
The rack noise was most likely normal pressure you heard with the system off. If you are unsure bring it in to an alignment shop. If there is a issue with one or both you will have to have an alignment done right after so its easier to have them do it.
Old Apr 14, 2010 | 10:40 AM
rcb2000's Avatar
there isn't an issue with the outter tie rods they'll move quit a bit. the Noise on the rack might be an inner tie rod that is bad.
phee's Avatar
I got the Shifts
but i must ask if you have bad motor mounts.
take it to a mechanic. they may be able to tighten them
Old Apr 14, 2010 | 10:41 AM
phee's Avatar
I got the Shifts
also, are your radius rod arms tightened? mine came loose and my car was scrubbing constantly on the drivers side
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Sep 25, 2015 06:05 PM
