Changing 2003 Headlight assembly
Old Apr 14, 2010 | 07:06 AM
Sam Ironblack's Avatar
I am looking for some help on how to change a 2003 tl front headlight (driver side) assembly. I have to change it because it has moisture in it. Thank you
Old Apr 14, 2010 | 08:35 AM
TLin401's Avatar
'13 Hyundai Sonata
Remove the bumper.
Wrong section.
Check out the 2G Section for the DIY bumper removal.
Old Apr 14, 2010 | 11:21 AM
KaMLuNg's Avatar
moved to second gen...
Old Apr 14, 2010 | 01:36 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Remove the bumper cover, then remove the bracket underneath the headlight assembly. There are three bolts - one on the fender side, then two side-by-side underneath the headlight. Then remove the two bolts on top of the headlight. One of those is also the grounding connection for the negative battery terminal on the driver's side. When you pull the headlight out, you will of course have to remove the bulb sockets. The HID ballast simply unplugs, but the low-beam, running light, and turn signal lights have to be twisted 1/4 turn counter-clockwise, then pulled out of the headlight itself.
Old Apr 14, 2010 | 02:30 PM
wside09's Avatar
고고씽
http://www.cardomain.com/ride/184466/18
good luck!
Old Apr 14, 2010 | 03:47 PM
fsttyms1's Avatar
Bumper removal takes all of 10 min first timers. Lay a blanket on the ground to help protect it incase it accidentally falls on you so that it doesnt get scratched.
saberlove
Mar 11, 2021 09:29 AM
acuraST
Sep 17, 2015 02:31 AM
Aleax
Sep 11, 2015 11:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
