Ticking sound
Ticking sound
i have a weird ticking sound on my 02 TL-P that looks to be comming from my driver side wheel. The other thing is it seem to only happen when my car has been driven for a few miles. Has this happened to anyone?
while moving or sitting still
while moving and i checked under the car and did not see any foreign or loose objects. The faster i go the ticking gets faster and when i slow down the ticking slows down also
and you cant hear it sitting still?
Nope it only makes the sound when it is in motion. It only happens if the car has been driven for a few miles. Maybe something stuck in my tire or loose bearings?
05 C230K & 09 135i 6MT
Are you sure your valves aren't rattling? If not, then I remember reading about an emissions control valve part (not EGR) going back and causing this problem. Search around for it.
jack it up and see if you can hear any thing by spinning the wheel
RickRoush03
if the ticking sound is only when the car is in motion i would assume you need to repack your front wheel bearing's, the other ticking sound common to the acura is that damn purge valce that is right next to the brake fluid resivour. i replaced mine, helped some, about $50. but if the sound is heard and becomes louder when and only when driving, i bet you need to repack your front bearing, i had to have my right rear done, cost $190 at the stealership, i had no choice at the time, not sure if the fronts are more.
we do not pack our wheel bearings.. they aren't even serviceable, they are pressed into the hub and if they make any noise or vibration whatsover, they are replaced...
the purge solenoid will tick constantly even while sitting still and the noise will NOT progress much at all.
the valve MAY BE a possibility, if they are bent you'd notice a power loss and they'd tick erraticlly, it's possible the are out of adjustment. i doubt it, though. Especially if you do not hear ANYTHING at idle.
MORE THAN LIKELY.. theres nothing major wrong with your car like everyone is getting you all hyped up about..
im betting money it's a rock or a nail in your tire..
Originally Posted by jpadilla
CV Joint? Is your CV boot torn? Is there a bunch of grease in your wheel well?
cv joints will CLICK on TURNS.. much deeper than a "tick"..
i'd take it to them and see what they say. it could also be if you had a rotation, one of the wheels isnt torqued properly and the caliper is hitting the rim.
no way in hell...
No Grease in my wheel well. Also, if it was a rock or nail how come the sound only happens after i drive the car for a few miles?
i spoke to a mechanic and he said that the wheel bearing would make more of a grinding noise than a ticking sound. I'm not sure were to go from here, when i go to the mechanic the sound does not happen at all.
a wheel bearing can make a winding sort of noise when the bearings inside are actually flattened out from extreme overheating. It will sound like a clock winding. That very well could be your noise, but i still vote for a rock or nail!
RickRoush03
Originally Posted by loud_whispers
no way in hell...
all i am doing is offering an idea, you never know, and before you say no way in hell, you'd need to be 100% positive that it couldnt even be that. i've seen it happen before, after installing a brake kit and it was b/c of the rim not torqured all the way.
Are you sure you Cant hear it at all while ideling? even if you slowly reve it while parked?
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
