Thoughts on purchasing 6MT swapped TL-P
I'm looking to see if there are any knowledgeable vetrans here that can help me with this decision.
The vehicle for sale is a '99 TL with:
-J32A2 swap
-6MT from 04 TL
Here's the rundown on what is done for the swap:
-Richie module
-02 TL-S ECU
-02 TL-S harness
-02 TL-S cluster (currently using the original TL-P cluster)
The issues that the car has right now are numerous:
Electrical:
-VSC, ABS, CEL, and SRS lights are on the cluster
-Speed signal not present
-Code reader shows Coolant temp sensor fault. (ECU side, as the gauge works)
-Haven't used the tester that was present before, but it also flashes:
-secondary 02
-EGR
-EVAP
Mechanical:
-Idle bounces erratically (likely vaccuum leak, but could be wrong)
-This is really weird: The shifter shifts the wrong way! ie. 1st is to the left and DOWN, 2nd is up, 3rd is middle and DOWN, etc etc. Reverse is to the very right and UP
Now, I do have full access to a repair facility, but I don't want to get into something that may be a total sh!t show. I believe that cars have souls and that nothing should be wasted, but at the same time, if it's going to cost me thousands in parts to get this thing up to spec, I don't want to get into it.
Let me know your thoughts on whether I should breathe some new life into this car.
It's really sad to hear and see this thing sitting for about 2 years, left to rot in somebodies apartment complex parking lot.
-J32A2 swap
-6MT from 04 TL
-Richie module
-02 TL-S ECU
-02 TL-S harness
Electrical:
-secondary 02
-EGR
-EVAP
Mechanical:
I Would Say; DEPENDS ON PRICE!
Cuz he has alot of Expensive Stuff right there, Even if he Fuckd Up the Install he already has like a 4.5K Worth of Parts (J32A2 + 6MT + Alot of Swap Parts) So you just need to fix some Random Things..
That Said if your not a DIYer Kind of Person; STAY MILES AWAY.
a car parked for 2 years is going to need a water pump- belts- hoses- etc
as well as the fuel contamination issues from hygroscopic action during long sitting
if you want a TL that badly, see the top part of any page here= USED CARS
thats `members only` selling,,not outside persons or dealers
meaning you can look up their previous post and know about the cars probs,,fixes etc
All sound like easy things to fix, and all the hard work has been done. If the price is right i would. Just need to figure out the wiring for the richie module to correct the issues and fix the shifter cables (probably installed wrong)
00 ssm
If it's cheap I would definitely get it. The mechanical things would be a breeze to fix. The electrical things seem like they would be the most time consuming, but not too bad. If Richie's module was installed improperly (and it sounds like it easily could've been) then it might have been damaged itself, which in the worst case you would need to shell out $500 for a new one. Even if it was damaged though Rich could probably help you with fixing it instead of getting a new one. There is also the possibility of the wire harnesses not being installed properly as well. Just a matter of going through it all and making sure it's all hooked up right.
sorry hung_lo i have decided to keep the car and fix it up at my buddy's shop thanks for the interested =)
cdn_rider i would not part out the car at anytime since i spent so much time and money in it.
would have been nice to know it was a ziner car to start with~
Good you have motivated the owner into fixing it!
Note: the stuff about 2 years sitting being bad- its real, and will contribute to probs-- old old fuel has need to be drained and/or seafoam the bageezus out of it! (2oz per gal fuel thru two tankfuls or half tanks)
the injectors and rails need a good cleaning anyway, that will get the pistons and intake valves too
same applies to oil, drain and refill before running engine,,or if already running add 1/2 can seafoam -run 15-30 minutes (as able) and change oil and filter
the buildup in there is unreal
actually car only been sitting for 15 months
2000 acura tl FPR
If you removed the driver's seat during the swap, chances are your SRS light was triggered from it. Do the SRS reset DIY and that should get rid of that light, otherwise you have a bigger problem.
As far as the erratic idle, when I did my swap, I forgot to plug in the ELD. Chances are, if you removed the under the hood fuse box, that'll cause some CELs and erratic idles. Here's what I'm talking about.
This plug
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_20120124_183331.jpg)
goes here
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_20120125_131244.jpg)
As far as your shifter issues, I think there was something special that had to be done with the transmission for those that use the TL models. (I used a CL transmission so I didn't have this problem).
I haven't addressed my ABS light quite yet.
are the speed sensors connected on the transmission?
As far as sitting goes, like the above have mentioned the fluids need to be refreshed, but if it's been sitting outside, much more problems. I was stupid and mine sat for a while and ruined my Rotora rotors. I'm just now getting around to replacing them.
Best of luck!
This plug
goes here
Best of luck!
http://www.youtube.com/watch?v=4t4ds8ae9tM
This plug
goes here
Best of luck!
This plug
goes here
Best of luck!
yes the speed sensor for the transmission isnt connect to the module and its a easy fix.
im also planning to replace all the suspension parts including all the brake line, rotors, pads.
-J32A2 swap
-6MT from 04 TL
-Richie module
-02 TL-S ECU
-02 TL-S harness
Electrical:
-secondary 02
-EGR
-EVAP
Mechanical:
-J32A2 swap
-6MT from 04 TL
-Richie module
-02 TL-S ECU
-02 TL-S harness
Electrical:
-secondary 02
-EGR
-EVAP
Mechanical:
For 99 TL you should use 99 harness an just change out speed sensor. The 99 speed sensor is only 2 pin connection an 00-03 are 3 pin. Also reason why your temp not working is b/c you need tap into engine just like Accord have to get temp reading right.
Here what i did:
![](http://img.photobucket.com/albums/v209/sillygrl404/6speed%20TL%20Swap/P1000151.jpg)
![](http://img.photobucket.com/albums/v209/sillygrl404/6speed%20TL%20Swap/P1000152.jpg)
For The shifter shifts it maybe cause your using wrong shifter pin . The 04-06 TL tranny is to right the CL an correct pin is the one to far left.
![](http://i16.photobucket.com/albums/b36/Richiev6/DSCN0232.jpg)
Good to hear that you will be finishing the project.
Car is definitely worth it for the parts, but time constraints and lack of familiarity of the project make me weary.
If you change your mind, let me know.
TLDude876
12-28-2016 03:18 PM
justin7779
12-25-2015 10:33 PM
