Thinking about NOS now!
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Ever since i got shitted on by that civic I was contiplating getting NOS. But I want it where the install is stealth and also if i ever take it out i don't want anything to show i had NOS in the car in the first place. also whats a safe shot? My friend can sell me his kit for 300 but with a 130 shot i think, i forgot what he said bt its in the hundreds.
'99 Acura 3.2TL Satin Silver
![](http://www.geocities.com/asian_dragon_picture_gallery/nicedragontext.gif)
also with 18's coming on soon i'm just slowing myself down so i need a quick picker upper ![](http://www.acura-tl.com/ubb/biggrin.gif)
![](http://www.geocities.com/got_rice4life/dragon.gif)
Received 1,080 Likes
Yo Mafioso,
Talk to Stylin Silver Sled. He's got a 60 shot I think. I don't understand much about what it means, but I think the higher the number, the more "bang" for the buck. I would think 130 shot would cause a nice fiery explosion under the hood. Could be wrong.
BTW, depending on what wheels you get, the weight difference may not be too bad. I think my C2s weigh about 22lbs each, so with 18" tires it's not too bad. Haven't noticed much of a difference.
I say get the VTEC controller first. It's less desctructive and might give you a nice boost in power.
1999 Satin Silver Metallic 3.2 TL w/o Navigation
- 18x8 Racing Hart C2s with Dunlop SP Sport 9000 225/40ZR18
- Comptech Springs, Sways, Exhaust, and Headers
- Red AEM CAI
- A'PEXi Digital VTEC AFC
- Factory Underbody Kit and Spoiler
- Clifford Intelliguard 9000 alarm
- Alpine 6 disk CD changer
- BEL 945i Cordless Radar Detector
- Burlwood shift knob
- Trunk tray
- 20% tint
Originally posted by NSXNEXT:
Yo Mafioso,
Yo Mafioso,
if thats the case, couldn't i just buy his set and replace the bottle with a 60-70 shot? how much do the bottles cost?
You replace the solenoid, not the bottle. Look at the Venom nitrous, it just has one solenoid and the computer controls waht show you want without havign to replace the solenoid.
The Acura Granddaddy
It's not the bottle that controls shot size, its the nozzle or jet. The numbers. ie 130 or 60 is how much HP boost to expect. It is the displacement of the engine that determines how much you should "squeeze". Bigger engines can take more than smaller. The upper limit for a V6 is around 85-100 shot. You can shoot more than that if you don't mind seeing your pistions put some "speed holes" in your hood.
Several Legend owners are using between 60-75 shots with no trouble. Hope this helps.
![](http://www.acura-tl.com/ubb/smile.gif)
ok, so if i buy the kit from the kid, it would work? even though it was from a 4 cylinder elipse?? I would probably go for a 60-70 shot. Mike tell me more about the solenoid, think it'll be expensive to replace? BTW what gains should i expect from the NOS when shot?
Wassup Guys,
I'm running a NOS Dry Kit(36 Jet/45-50HP)
for NOS company there is mainly (2) different systems
(1)Dry Kit - Simple and universal kit that taps into your air intake. HP between 40-100
(2)Wet Kit/Fogger - Shots into the intake manifold or comes with a plate. HP between 80-250
If you run a Dry Kit(45-70HP) and it's properly installed, colder plugs(with a small shot, there is no need to retard the timing) I use NGK "V" 1 colder(I think 6) and gap it one down(Factory - 44, NGK - 40), and do not abuse it.. You shouldn't run into any problems.
It sounds like he's selling a dry kit($300)
I would go to your local Import Shop and order a smaller jet(40-70HP), I would start small because at first I wanted a 70HP shot but with the (45-50Shot, Exhaust, Headers and Intake) I ran a 13.99. Well enough to smoke a CVC
Then if you feel you want more, go a jet higher(just remember that the higher you go, the more stress we're putting on the trans! but Stylin' is running a 70HP Shot and it's all good) I do not recommend anything higher than 70HP Shot!!
As for setup.
I would set it up we're it activates the solenoid only on full throttle and the main toggle switch has to be on! This is a double safety(If something should go wrong, release the gas or turn off the toggle and the NOS shuts off).
Also, about the bottle, I'm not sure how much it cost but it's a good idea because with a 45-50HP Shot, I only get about 60-75 sec. of Juice which cost about $40-50 a refill.
Finally,
I cannot begin to explain the kick you get with a NOS setup, not like turbo or SC(no lag, not progressive) instant 45-70HP talk about a head jerker and wheel spin!! If you want to sell it and take it out, it's simple, since your only tapping into the air intake, just replace the air intake with your factory one.
As for setup.
Finally,
hmmmmmm, so i don't need to press a button for the NOS to shoot? all i have to do is stomp on the gas and thats it? wow i gotta see where i can get it set up that way around my area. if his right now is a 130 shot how much would it be to replace it with a 60- 70shot? and with those 60secs how long doesn't that usually last you?? (sounds like a stupid question but i mean if you stomp on the gas does the nos keep shooting till you let up or does it just shoot once till i press it again?) thanks
![](http://www.geocities.com/descendantsofthedragon/WLung140x215L.gif)
MafiosoTL, if your only mod in the car is the intake, I would recommend going with something else first other than NOS.
Considering that the TL actually drops out of VTEC when making its shifts and you already have an intake, a VAFC would probably help your car alot. No it's not going to drop your 1/4 mile times as much as NOS will, but you will be able to enjoy it every single day.
NOS is the cheapest way to get lots of horsepower, but you can't use it all the time either. Venom's kit is very nice, but also very expensive. You make the call.
well i'm getting it not for everyday use. just incase some sleeper civic tried to sneak up on me ![](http://www.acura-tl.com/ubb/biggrin.gif)
I've never sat in a car with NOS, but how long after you hit the button does the boost last? Minutes? Seconds?
'00 White Diamond Perl w/Nav
Wings West Spoiler
Comptech Exaust
Rear Comptech Sway bar
AEM CAI
Wings West Spoiler
Comptech Exaust
AEM CAI
day.
day.
True the NOS does last a short time but say your racing a CVC SI which beat you off the line, It takes time for our V-Tec to kick in and our car is about the same weight as an elephant
So I understand that NOS isn't a constant boost but, I never said it was. If you use it in a similiar situation, it should last you awhile. I mean personally I wouldn't run NOS straight for 60-75 Sec. constant!!!
PhiTL,
I have a 36Jet(45-50HP) and I run 13.99-14.27, I had about 4-5 runs. How long it last depends on what size jet you use, the bigger the jet(higher HP's) the faster it'll run out!!
once you hit full throttle..give it at most 1 second...or less...much less.....and you'll blast away!
Mugen exhaust
now ordering AEM short ram
Mugen exhaust
Thanks Tanner, what about how long does the extra horse power stay at its peak? When the bottle runs out, or when you let go of the trigger/full throttle?
Wings West Spoiler
Comptech Exaust
AEM CAI
Wings West Spoiler
Comptech Exaust
AEM CAI
So tanner or whoever else has NOS, where does it tap into in the engine? do i need to cut anything? I just want it so i can take it out and have everything back to normal easily. also to replace the 130 jet with a 60-70 shot how much does that usually cost?
![](http://www.acura-tl.com/ubb/avatars/nicedragontext.gif)
Not sure how much the jet cost!! The Dry Kit taps into the air intake about 4" from the throttle body and to take it out you would need to plug up the hole in the intake or replace it with the stock intake and of course take out all the hoses, solenoid and wire. It'll take about 3-4 hours to take out.
PhiTL,
As much as it's instant power, it's instant power lose when the NOS is shut off.
PhiTL,
rockyboy
12-06-2022 02:29 PM
nuldabz
09-03-2015 05:49 PM
