Thinking about getting rid of OBX headers
I've had OBX headers for about 12K miles now...and I think I've had it with the resonance.
Makes my near-lux TL sound like a lawnmower at times, although my car IS faster.
Has anyone noticed that the resonance is louder when the AC is on?
Just bought some new header gaskets...don't know if I should put the stock headers back on, or just sink the $1K and get the comptech ones.
As for the comptech headers...I've read that the early ones have resonance issues also, so how do I tell if I'm getting an old one, or a new one?
Thanks in advance.
Thanks in advance.
mushroom mushroom
I have VERY little or no resonance but I have the CT exhaust to accompany them...I live in Arizona so I almost always have the A/C on and I notice no difference. I don't know what to tell you but maybe try tightening your headder bolts a bit sometimes they can come loose and cause some unwated noise at certin RPMs. It's worth a shot.
good luck
good luck
good luck
good luck
Originally posted by chuckstl
I switched from OBX to CT over six months ago and it has been great. You won't regret it. Just find some used ones, about $700 is right.
This is a probably a stupid question, but do the CT headers turn color like the OBX ones?
I had forgotten to polish the OBX headers before I started running my car, and now they are a gross gold/splotchy color.
I just don't want to purchase a set of used CT headers that look just as bad as my OBX's...
Thanks!
Re: Thinking about getting rid of OBX headers
Originally posted by Elementz
What's resonance? Seriously, I'm a noob.
It's a buzzing sound coming from the engine area at certain RPMs. For me, it's like at 1500, and ~2900. Right after you pass those two points, it's gone.
Originally posted by tl-steve222
Right.... CLC, are you leaving it like that?
I want to get new headers, but man, it's hard to sink $1200 right before the holidays.
I'm going to make sure my OBX header nuts are torqued down to 23 ft-lbs this weekend, and see if that alleviates the problem. I haven't retorqued the nuts since the header installation a few months ago. Hopefully, it'll bring the resonance down low enough to my taste, so I wouldn't have to spend the money for the Comptech's.
G
Acoustic resonance - Intensification and prolongation of sound, especially of a musical tone, produced by sympathetic vibration.
One example: Resonance is the sound you hear when you blow across the top of a coke bottle...
Thanks!
Blown is Best
Parts for Sale
Originally posted by randomwalk101
I wrapped my OBX with header/thermo wrap...no resonance whatsoever...keeps it cool too..but looks like a mummified header..hehe
i wrapped the whole header...all the way down to the o2 sensor. Looks like crap but hell, my car is not a show car, and if the hood is closed, nothing shows. It really keeps the engine bay cool (ei. temperature). I believe it's called DEI thermo header wrap. You can buy it at www.summitracing.com
So after the thermal wrap how did everything go? Any resonance issues. and for all you OBX header peeps... did you headers leak or break welds? How long have you had it as well
Also stone headers.. where, how much? pics?
I heard the Thermo wrap might work to well! So well, it could melt the pipe! :wow: "Return to Sender" and got a refund. Still dealing with that small humm @ 2300 rpm. That is my only issue with the OBX header..... 3rd to 4th is SWEEETTT..WWUWWOOOOO!!! you know what I'm saying.
you shouldnt have a problem with melting the pipe. the people who have encountered that are people with MODIFIED (usually turbocharged) high output engines. stock engines SHOULD NOT creat that type of heat that would cause that.
the tape is nice because it will reduce under hood air temp there by creating a better enviroment for the engine. i would say REORDER it and use it.
I love the OBX header but the resonance is getting to me as well. But I don't want to get rid of these headers because my girlfriend got them for me because she knew I wanted these headers for a while too. Oh well I think I might try that thermal wrap though.
Retorque those bolts, they can work themselves loose sometimes, and it coudl help.
Also about the header wrap, it does do a good job keeping the heat inside the headers, but if your headers were to crack, or a weld were to fail, etc, you will be out of luck. No one will warranty a header that has that Thermal wrap on it
Purchased: April 28, 2001
Originally posted by Mr Hyde
Retorque those bolts, they can work themselves loose sometimes...
TL-S driver
tighten the bolts and get exhausts. The biggest way to get rid of it, is don't floor it in 3rd, drop to second and go. the lower the gear the faster it blows past the 2500 mark so you won't hear anything anymore. works for me!
snorf
11-04-2019 06:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
