Is there specific fuse for this?
Old Mar 25, 2013 | 07:03 PM
thewrangler99's Avatar
I am not getting power to this wire; is there any fuse that I have to check? The upper section of the defroster grid lines doesn't work and I think it's because of this wire connector that's not getting the power. Please help!
Old Mar 25, 2013 | 09:30 PM
my240sx4u's Avatar
fuse might be getting power but have you check the relays?
Old Mar 25, 2013 | 09:50 PM
assclown's Avatar
2000 acura tl FPR
It's number 16
Old Mar 25, 2013 | 11:20 PM
I checked the fuse under the hood and it's fine. As I tried to turn the defroster on and checked the current in the bottom grid lines and there was not current. So, the fuse is good.
@assclown where's is this located? I checked both the driver side and passenger side fuse panels and there's nothing labelled related to defroster.
Old Mar 26, 2013 | 02:45 AM
Edward'TLS's Avatar
6G TLX-S
The #16, that Assclown was referring to, is a relay, not a fuse.
Old Mar 26, 2013 | 06:31 AM
fsttyms1's Avatar
Is that the ground wire? If the lower half is working but the upper half isnt id look for a break in the defroster line near where the defroster stops.
Old Mar 26, 2013 | 09:18 AM
assclown's Avatar
2000 acura tl FPR
Yes, ooops, didn't see there was a #16 fuse on that figure.
Old Mar 26, 2013 | 04:11 PM
If I trace the grid lines; upper grid lines have separate power source compared to bottom grid lines. The bottom ones are getting power from the sides.
Old Apr 3, 2013 | 03:40 PM
TLer trash's Avatar
Those upper grid lines, top 3 on pass. side, top 5 on driver's side, are the radio antenna. They're not supposed to have power or ground, just continuity to the connector in your picture.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Acura604
20
Aug 5, 2017 12:55 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
