Themo reading!!!
Old May 27, 2007 | 11:48 PM
SlickJay12's Avatar
Exclamation Themo reading!!!
Hey guyz I've a 2000 tl. The Thermo in the car is not readin the right temperature outside? Example if it's 70 degrees outside it will read it as 80 or so. Pls help... it's buggin me out.
Old May 28, 2007 | 12:09 AM
randomthought's Avatar
rebmeM deretsigeR
Is this when the car is just started or after it has been running? It takes a bit of driving for it to read correctly. Some certain speed or something, can't remember.
Old May 28, 2007 | 12:49 PM
SlickJay12's Avatar
after it's been running.
Old May 28, 2007 | 04:11 PM
01tl4tl's Avatar
Likely culprit is the oil reminder/temp adjuster button on the dash
If you turn the key on and press both trip and reset buttons together- the temp adjust display comes up and you can adjust up or down.
Usually I go to reset the oil minder and do it backwards of when the key should be on- resulting in temp change
Need to drive to get airflow and more accurate reading
Check outdoor temp gauge placed in shade- then drive and adjust
Best reading is to remove sensor under bumper and place in ice water- adjust to 32 degrees
Hope that helps
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
