tein ss help
Old Oct 6, 2004 | 10:07 PM
acuratl02's Avatar
tein ss help
hey guys i just installed my tein ss coilovers...i need to know which way to turn for soft and which way to turn for firm...and also how do i adjust the rear coilvers..i want to go 8 in the front and 8 in the back
Old Oct 7, 2004 | 02:35 AM
redryder83's Avatar
SpOon!!!!!!!
Right clicks are stiffer, left clicks are softer. 0 being stiffest, 16 being softest.
Old Oct 7, 2004 | 06:17 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
dont you have the manual (for soft/stiff)? turn the knob all the way clockwise and then start counting, 16 clicks counter-clockwise is the softest (from what i remember) so in your case turn the adjustment knob 8 clicks counter-clockwise.
To adjust the rear damper you have to take off (or atleast loosen up) the rear deck.
Old Oct 7, 2004 | 09:06 AM
99TLHeather's Avatar
You should always turn the knob clockwise till it doesn't click anymore, which it's at its stiffest than click counterclockwise (make softer) to what you want to set it at. Just don't go past 16 clicks cause you may damage the coilover.
Old Oct 7, 2004 | 02:54 PM
njzprettyboy's Avatar
how do you remove the rear deck?
Old Oct 7, 2004 | 03:33 PM
You don't really have to remove the rear deck. Just take the screws off between the backrest and the seat itself and lift the backrest up off the clips and pull it towards yourself. Than push the deck up a bit till you can reach your hand in to adjust the knob.
Old Oct 7, 2004 | 11:48 PM
did it for him today! it was easy, thanks guys!
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
4drviper
Sep 23, 2015 07:42 PM
