TCS and VSA
Old Sep 20, 2003 | 05:50 PM
TimN88's Avatar
TCS and VSA
When i push the VSA button, does VSA actually turn off, or is it ust TCS that turns off? I ask this because when i push the button to disable it, the VSA lght stays off, but if i slide the car or ebrake a corner, the light then comes on. Am i confusing the computer because its trying to stop the skid because the system is still on?
Old Sep 21, 2003 | 09:13 AM
maxx96's Avatar
New Life
Ok you have an '03 TLS, good, the way this woks is the VSA light should be "OFF" at all times unless you push the VSA button, at this time the ! yellow caution light will come "ON" letting you know that your car's stability control was disable. VSA and TCS work together on the '03 TLS. Something is wrong with your car because you said that when you push the VSA button the light stays "OFF". Take to the dealer to have it check, also this is explained in the vehicle's manual.
Old Sep 21, 2003 | 11:11 AM
TimN88's Avatar
the triangle with the exclamation point comes on when i push the VSA button, just like it should. But if i really get the car out of line, the VSA light comes on. i think its in the lower right of the instrument panel.
Old Sep 21, 2003 | 11:25 AM
bigman's Avatar
'Big Daddy Diggler'
when you turn the car on the VSA is automatically enabled everytime. To disable it, just pres the button, and that will turn the trangle with the exclamation point on, letting you know that you disabled vsa.
Old Sep 21, 2003 | 11:42 AM
hzm82's Avatar
bigman is right, VSA/TCS comes on automatically when you start your car. The button is to disable it, the light will come on and tell you its disable. If you never press the button and you get into a situation where VSA/TCS is used....the light will flash to warn you its being used. If you press the button and the light doesn't come on, take it to the dealer.
Old Sep 22, 2003 | 12:55 AM
TLSAnthracite's Avatar
I seem to have sort of the samething too. When i drive over a pot hole sometimes, the triangle exclaimation point light flashes, or when i floor the car and the surface is bumply, the light fashes too. I always just thought the the car would know when u want it to turn off VSA when ur drifting or cornering. i guess i was wrong
Old Sep 22, 2003 | 01:42 AM
hzm82's Avatar
Why would the car know to turn off VSA when you're drifting (and you can't do control drifts in a FWD car anyways)? its there to prevent that. Thats what the button is there for, so you can turn it off. You can't expect the car to read your mind do you?
Old Sep 22, 2003 | 05:30 AM
josh stein's Avatar
Does the 1999 have TCS and VSA?
Old Sep 22, 2003 | 08:26 AM
that light
I think it does double duty - it flashed when it's working and solid when you push the button to turn it off.
Old Sep 22, 2003 | 08:44 AM
stiletto's Avatar
I think you are all missing the point...
VSA button, just like it should. But if i really get the car out ...of line, the VSA light comes on. i think its in the lower right of the instrument panel...
I would have to re-read the manual to be certain, I think that the VSA light (the amber letter light) comes on to indicate VSA system failure.... The amber triangle light indicates that the VSA system is working when it is intermitent.. and that it is disengaged when it is constantly on. In any case, to clarify your doubt. READ THE MANUAL. I know I wiill this afternoon... :-)
Old Sep 22, 2003 | 09:06 AM
maxx96's Avatar
New Life
Let's put all this to rest check this site: https://www.ahm-ownerlink.com/assets...man/2003tl.pdf
It will give you all the info on VSA. Page 61 and 206, 207 & 208.
Pay close attention to the part that said VSA AND TIRES SIZES.
Old Sep 22, 2003 | 11:40 AM
hzm82's Avatar
No only TL-S have VSA, 99-03 TL-P have TCS.
Old Sep 23, 2003 | 09:15 PM
josh stein's Avatar
What are the differences?
Old Sep 24, 2003 | 12:10 AM
hzm82's Avatar
VSA includes TCS. VSA detects oversteering/understeering or skidding, it can reduce engine power, use % of the brake power to correct these. TCS just detects drive-wheel spin slippage and apply % of brake power to correct this.
Old Sep 24, 2003 | 12:16 AM
The Acura Tranny Killer
i love "bumply" roads..
Old Sep 24, 2003 | 01:50 AM
So when it flashed does it mean it's working or does it mean it's off? And i was just wondering if anyone esle had that exprience before.
Old Sep 24, 2003 | 07:53 AM
yes
if you hit a pot hole it flashed becuase the car detects that your wheel has "left the road" as it were. Same for flooring it on not so smooth pavement. That's why they tell newbies like me to turn it off before I wanna do a redlight race
Old Sep 24, 2003 | 09:52 AM
bigman's Avatar
'Big Daddy Diggler'
When the excalamtion point is off, but starts falshing when you are driving, the vsa is doing its job and adjusting for traction and stabability.
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
polish_pat
Sep 30, 2015 12:22 PM
Allen_442
Sep 8, 2015 06:01 PM
