tcs light
Old 06-19-2008 | 02:02 AM
thinhthan303's Avatar
tcs light
my tcs light comes on after a little bit after i drive than stays on. do anyone know the reason why it does that and my check engine light is on and i went to diagnosic and it said something about insignificent gas return or something like that? can any one help me with this pleaseeee,
Old 06-19-2008 | 04:01 AM
01tl4tl's Avatar
go to autozone and ask for the codes to be read for you again- come back with the letter number combos they give you
May be insufficient egr flow- the egr ports get plugged up in the intake manifold- takes less than 2 hours to remove and clean- and re-install- then reset the computer
Old 06-19-2008 | 09:14 AM
totaledTL's Avatar
Hmm doesn't make sense to me that the TCS light would come on too unless you had 2 problems. You can get those code scanners pretty cheap now, got one for $40 recently.
Old 06-19-2008 | 01:53 PM
yea it is a insufficient egr flow can anyone show me how to take out the intake manifold or should i get someone else to do that? when i wen to go get the code it dosnt say anything about the tcs light it just said insufficient egr flow.
Old 06-19-2008 | 07:47 PM
01tl4tl's Avatar
https://acurazine.com/forums/showthread.php?t=156252
DIY on egr port cleaning
Old 06-20-2008 | 01:32 AM
what is the thermoblok spacer? am i suppose to do that too? is it easy to take off the intake manifold and clean it cuase i dont wanna take it apart than not able to put it back on
Old 06-20-2008 | 03:04 AM
01tl4tl's Avatar
thermoblock is an optional part many of us run-
for now- just follow the physical removal of the manifold and EGR port cleaning that is part of the DIY
Skip the install thermo spacer
Buy new intake manifold gaskets at dealer- just tell the parts guy what you are doing, they will hook you up
Read the DIY a few times and look under the hood
Its a little scary when you look at it, but not difficult if you have basic skills and the correct tools for the job.
If you are not confident- pay a shop 1.5 hours labor- about $150 to do it for you
Use a private honda shop that knows what you are talking about when you say `the EGR may be plugged` I am getting a low flow code
If they want to replace the EGR valve- keep looking for a good shop
Old 06-20-2008 | 04:54 PM
thanks alot for the tips
Old 06-20-2008 | 05:06 PM
i called the dealer and they said it might need to be drilled or something and they said if i get that code it might need a new valve. is that true?
Old 06-20-2008 | 09:44 PM
01tl4tl's Avatar
on 99s iirc- acura had a service bulletin on the egr port -that year had only 1 port and it clogged easily- so they drilled out the hole slightly- then put in a metal sleeve- which made it just as likely to plug up again-
new years, 00 on- have 6 egr ports cast into the intake manifold- you clean the crud buildup from those and rinse out the intake manifold in general.
EGR valve may be bad- but the likely culprit is the egr ports themself.
the valve opens and closes- if its doing that- its fine
When the ports are pluggsed- flow is reduced...sensor picks that up....
Old 08-15-2008 | 12:50 AM
so i do need to drill?
Old 08-15-2008 | 03:01 AM
01tl4tl's Avatar
check with acura on a 99 they may still be doing the egr cleaning for free -
the drilling is to install a smooth bore tube that supposed to cut down on the problem but doesnt really-
Old 08-16-2008 | 10:04 PM
so i should be good with just cleaning it right?
Yikes
05-03-2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
09-18-2015 10:26 PM
Bahamanurse1
09-10-2015 10:05 PM
Allen_442
09-08-2015 06:01 PM
Quick Reply: tcs light
