TCS
Old Nov 14, 2000 | 08:44 PM
Guest
Guest
Posts: n/a
Post TCS
Hey i just wanted to know does it make a differece if i leave the tcs light on or if i leave it off?
Old Nov 14, 2000 | 09:14 PM
Post
If you leave TCS off it doesn't work and if you have any tire slippage your car will not compensate for it and you will have to control it yourself.
Trust me it definately does! IF TCS is off, and you floor it, you will have a nice little burnout
I usually leave it on, but if you notice when you turn off TCS and restart your car, when the car starts up again TCS will be on again.
'00 White Diamond Perl w/Nav
Wings West Spoiler
Rear Comptech Sway bar
Old Nov 14, 2000 | 09:16 PM
FTM-1's Avatar
Post
Well it works this way every time you start the car the TCS system is ON.When the yellow TCS light is constant yellow the system is OFF. When the light is OFF the system is ON.There is no need to push the TCS button to turn system OFF unless you are racing or trying to get the car unstuck. The system is a low speed system & works at speeds up to 18MPH.
So every time you start the car even if you turned the system OFF the last time you drove the car system will reset automaticly to ON.I hope I did not screw you up with all that but thats what it is YELLOW LIGHT ON THE SYSTEM IS OFF when LIGHT IS OFF SYSTEM IS WHEN YOU RESTART CAR SYSTEM IS AUTOMATICLY ON.WHEN THE WHEELS SPIN THE LIGHT WILL BLINK ON & OFF
Old Nov 14, 2000 | 09:23 PM
FTM-1's Avatar
Post
WHEN LIGHT IS OFF SYSTEM IS ON.
I got it correct for sure.
Old Nov 14, 2000 | 09:34 PM
Guest
Guest
Posts: n/a
Question
huuuuuugh???/ why would they make it that when the TCS ligh tis on that it is off and when the TSC light is off it mean its on?...........damn it im getting confused
Old Nov 14, 2000 | 10:00 PM
FTM-1's Avatar
Post
I was also when I got the car almost a year ago.But I think they make it this way because the constant yellow light being on will remind you that the system is turned off. Its all in the owners manual but I did not read fully when I got the car.I learned this at the new car onwners clinic at my Acura dealership. People were asking questions about there new cars.
Old Nov 14, 2000 | 10:19 PM
NighthawkBlack's Avatar
Post
I think the idea behind it is it is warning you that it isn't going to work. The same way the SRS sideairbag light comes on when someone leans in the passenger seat or the washer fluid light comes on when it is empty.
Old Nov 14, 2000 | 10:22 PM
FTM-1's Avatar
Thumbs up
Thats correct
Old Nov 15, 2000 | 08:10 AM
Arrow
The biggest reason to leave it on is that the f*****g light is so bright and annoying...
Just my 2 cents...
Old Nov 15, 2000 | 04:35 PM
mentl's Avatar
Post
I admit it... I thought TCS was normally off too. I was all ready to turn it on this winter until someone on this board set me straight.
Someone here pointed out that a FWD car with this much power really needs TCS. That makes sense to me.
Since then, I've noticed the light come on a couple times on rainy days and once when I spanked a Suburu
2000 Navi TL White Diamond Pearl
(they're magically delicious)
Old Nov 15, 2000 | 11:59 PM
Guest
Guest
Posts: n/a
Question
Thanks for the help. I always thought that when the light was on then its on but when the light is off its off. Thanks for clarifying that
Guest
Guest
Posts: n/a
Question
Yikes
May 3, 2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
Sep 18, 2015 10:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
