Taking a trip
Taking a trip
I plan to go on a 300mile/5hr road trip this summer and I was wondering what things should I have checked out on my car before I go, because I dont want any problems. Last time I took a trip my car ran fine then suddenly overheated AFTER I got to where I was going wich was about over 150miles away, I thought I was going to end up stuck. That problem was solved, all I needed to do was replace my bad radiator cap, I also got a full coolant flush when I got back, this was a year ago. The things I plan to have done; Mobil 1 5W-30 Oil Change, Transmission Fluid Change w/ crush washer, Top off Coolant, Tire Rotation/Pressure, Purolator Air Filter A25249. What else should I look into, any trouble spots in the tl while on the road? Overall my car runs very well as a daily driver, its a 99 w/ 150k miles
Porkchop Sandwiches!
Thats a short trip, if your car isnt acting up you should be ok. Check your tire pres. before you leave, make sure you're not leakin anything. Thats all i can think of.
Because it tends to result in total failure of the trans a week later!!
read the trans failure thread and many post are- I had the fluid changed last week and now it revs and doesnt want to shift- what do you think the flashing D5 and TCS lights mean? I am not in TCS mode!!!
Thats if its got the average miles on the original trans-
ignore me if you have a replacement trans and are on 15k changes just for fun
top off coolant? are you losing coolant from the overflow bottle- its pulling it below the lower mark? thats not good
run tires 2 psi above normal for extended high speed-freeway drive
300 miles is nothing I can do that in a day of fun run to Yosemite and back
some people do not understand that the modern engine is a crud factory - as every minute its creating unburned and partially burned fuel- hydrocarbons- water vapor and oil, some of that gets deposited along the walls of the oil gallies, the intake valves and piston tops and rings. Gas additives mandated by the govt clog fuel injectors and ruin the fine mist easily combusted air-fuel mix they were designed to make
You dont have to do it- but since everyone reports smoother running and generally better fuel useage and lower emissions- educated members love the stuff
And look at the dodge truck firum and hi performance boat forums-
guess what they use to keep the engine in top condition
If you dont want to use it that is your choice- but dont say it doesnt work when we all have proof it really does
i dont believe in seafoaming
Probably dont believe in aliens either do you
300 miles / 5 hours : Doesn't sound like much of a road trip to me... you should be fine with:
1. Checking fluids in the car (windshield, brake, power steering, etc.).
2. Check your windshield wipers
3. Brake rotors and pads
4. Coolant level
5. Cabin Air filter (5 hours is a long time to be breathing in crappy stale ass air)
6. Oil Change and gas it up
I would highly recommend Seafoam..... I did it and I saw gains immediately... The biggest one being the increase in mpg... I usually get the fuel indicator on around ~330-340 miles, I am at 370 and the needle is still a good ways from the empty line... this is repeated... not bad I think...
Good luck with the trip...
4. Coolant level
mada51589
Jan 9, 2025 04:40 PM
, check spare tire pressure.
