Taillight Tinting (Spray not Film)
Advance
Has anyone tryed using a spray on taillight tint? I bought this taillight tint that is in the form of a film and I totalled fuxed up putting it on. I think it would be easier to use a spray. I know this can be done professionally but is there a cheaper alternative you can buy at Kragen or other parts stores? please chime in
I would get it done professionally cost about $50 if you prep the lights your self. It also last longer then the do it yourself spray because they will spray it with same clear they use to paint cars. Since they spray lights with clear you can wax them when you wax your car and you will get a high shine.... also the do it yourself will fade over time.
Advance
Thing is finding a place to do it for that cheap... I'd think most shops would charge 100+ and I definitely dont think thats worth it. What if you used a tint spray than used a clear coat spray after? don't you think it would preserve the color?
If you prep them before you take them to be sprayed they shouldn't cost no more then $50. Take out your tail lights and wet sand the shit out of them with 1500 grit then take them to a good body shop. You can pick the color of the tint also the tint is just candy mixed in clear. Well worth the $50.
No wet sand them and take them to have them sprayed. Won't turn out the same if you do them your self, unless you have a paint gun and you have good clear. I like using PPG's clear just painted my girls 99TL today hands down best clear for the money.
No the aerosol cans don't have the same hardeners that make the clear strong like the clear on your paint. The aerosol clear will normally fad in less than a year if you wash your car regularly giving your tail lights that ugly hazy look.
You still can prep them your self to save money just be sure to tell them what you did. Steps are below.
1) Take out tail lights
2) Wipe them down with paint thiner/lacker thinner (Not striper be sure to pour the thinner on a rag don't pour it directly on the lights). This is done to remove the road grime, polish that may have gotten on the lights ect.
3) Use 1500 grit wet sand paper use plenty of water and sand the lights real good should take about 20min to do each light
4) Finally tape up the back of the light using green painters tape and newspaper.
After this is done all the shop that is going to spray lights has to do is scuff them and spray them. Should safe you about $50 - $70
No He Can't
Any reason you are against the tint besides messing it up?
Remember that the spray cannot be reversed, so if you get tired of the look or have some type of legal problems with them and get a "fix-it" ticket, you would have to get new tail lights instead of just removing the film from them.
If I were you, I would go for the tint
Advance
I've gotten the tint and tryed it but messed up bad luckily the ebay seller refunded my money without me needed to return the "messed up" product.
pwnage
1 Post
I had a hell of a time getting my tail tint's to work to but finally after persistence I got them and I love them now. Think about giving the tint another shot before you do something perm to them.
No He Can't
i used the aerosol can and dont have any problems...i know most ppl dont agree but it works fine and its on 10 bucks...i wet sanded them and then used the tint spray and use auto clear in a can to giv it that car gloss..they still look brand new...i did that a year ago
Repeat Offender
Same here, I used the aerosol on my Civic's tail lights Spring 06 and they still look good. The only reason I had to start over is because I sprayed too much tint on and completely blacked out my tail lights when I was just trying to get a dark red look.
No He Can't
Bippu Style only please
There is a spray tint, I believe it's called VHT Nightshades. If you can pull apart the tail-lights, it's best to prep inside, then spray the interiors. You don't have to worry about a lot of the bleeding/fading hassles with this method.
That is, if the tail-lights can be pulled apart.
Repeat Offender
I wouldn't pull apart your tail lights and spray the inside, that's just unnecessary hassle. Then you have to worry about the glue that keeps your tail lights together. As a matter of fact, I didn't mean to make an endorsement out of my statement, I just wanted to clarify that if done correctly it will look pretty badass. That's not to mention the 6 hours I spent on tinting my tail lights.
I would recommend getting them done by professionals, it's a lot less worry if you get the right shop/person to do it.
I gotcha on that, I'm just used to doing work on my car myself. Not everyone has the bank to spend on shop time and such.
If you know what you're doing when you open lamps, you can get them back together, and usually a good silicone based adhesive will give you trouble free use if the adhesive they used doesn't hold.
vht nightshades is good...justsearchon ebay for spray tint...i wet sanded wit 1500 grit by the way and the put ona coat wet sand again the another coat wet sand again...andthe like 3 more coats...looks pretty dam good...i have to redo them cuzsum1 scuffed em wit there truck a holes
Put the shoes back on in
Advance
I'll just save up and have it done professionally... I just painted my brake calipers and they match the taillights quite nicely might not end up getting them tinted... we'll see. Btw Ramojr the link doesn't work.
Nah, i was just messin around one day and came across the page.. Didn't have to sign up for anything.. Weird.. Maybe this one will work..
http://www.350z-tech.com/zwiki/How_to_Smoke_Taillights
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
