Tail Lights
Old Nov 18, 2003 | 04:04 PM
ROBTL's Avatar
Tail Lights
Anyone can help on removing the tail lights on a 2000 TL Im having trouble with the carpet I cant pull it back far enough to reach all the nuts. How do I get the center panel out? Thanks for your help
Old Nov 18, 2003 | 09:02 PM
TLMugen's Avatar
I'd rather be driving:
Lightbulb
First you have to pull up the carpet (it's really the trunk floor) using the string with the hook; it's hinged toward the back seat which makes it easier to remove. Then you remove the grey plastic trunk latch cover. You'll see four "screws" on top (they're basically just plastic pins), just unscrew them a bit and then just pull them out; then pull out the anchors that the screws were in. The plastic cover then just lifts off. You'll then be able to pull back the carpet side trim (after unscrewing the tie down knobs) enough to reach the six tail light housing nuts.
Hope this helps!
Old Nov 18, 2003 | 10:01 PM
ROBTL's Avatar
Finished!! Thanks for the info I switched the tail lights to the the 2002-up half red and clear tail lights
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
brjones9
Sep 3, 2015 07:30 PM
